Old 07-14-2004, 09:20 AM   #1
plainzwalker
plainzwalker is on a distinguished road
Default car stereo question
I just got my wire harness in from crutchfield and when I went to go make sure it fit correctly I noticed that it has 4 less wires then the one in the car. Any idea what those cables could be for? It has the 8 for the 4 speakers, it has the antenna, ground, illumination, and the 2 different power sources. The wires arent labeled in the car so I'm at a loss, only idea that I can think of is that it there was an option for a cd changer and this is were it would of hooked up... When I bought the car it didn't come with a stereo so I can't figure it out this way...
Any clues?
Thanks
Jeff
Add to plainzwalker's Reputation
Rate the quality of this post and help plainzwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plainzwalker is offline
Old 07-14-2004, 10:32 AM   #2
Lucas1
Lucas1 is on a distinguished road
Default
only hook up the ones your car has. the others are probably for power antenna, dimmer, or not used. radio makers usually use one generic harness for all of their products. there should be a diagram in the instructions.
Add to Lucas1's Reputation
Rate the quality of this post and help Lucas1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lucas1 is offline
Old 07-14-2004, 01:04 PM   #3
sierrap615
sierrap615's Avatar
Default
what year?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 07-15-2004, 11:03 AM   #4
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default
Ok, all you REALLY need is the power, ground, ACC, and the speaker wires. Everything else you don't really need to power up your deck. Don't worry about the extra wires, especially when you have a wiring harness/adapter.
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 07-15-2004, 11:08 AM   #5
geartooth94
geartooth94's Avatar
Default
more specifically about not worrying...tape off or otherwise insulate any wires you won't be using. This will keep them from touching any metal chassis parts and shorting out.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline
Old 07-15-2004, 12:18 PM   #6
plainzwalker
Default
It's a 96. I wasn't worried about them that much, I was just wondering what they could of been used for.
Well from start to finish, including the wire prep work it took me about 20 minutes (not including the drive time up to my work to prep the cables).
Thank you for the help
Jeff
car stereo help irondiezl3 S-Series Mods 25 11-07-2007 03:05 PM
phone car kit/stock stereo question phealy Ion General 6 07-07-2005 06:51 PM
Car Stereo Question (CD/MP3 Player) daver Ion General 2 06-30-2005 08:15 AM
What kind of stereo do you have in your car? Arnel General Saturn Discussion 20 06-03-2003 04:35 PM
Car Stereo Information Whelan Ion General 1 03-10-2001 10:10 PM
