Old 06-26-2018, 01:39 PM   #1
mjollnir79
mjollnir79 is on a distinguished road
Default New oil, old filter, can I replace the filter if there's oil in the car?
Hello everyone.
I wanted to start doing my own oil changes in my 2006 saturn ion. I've done oil changes countless times in other cars. However after I drained my oil, put the plug back in and on to the filter... I'm usually used to just unscrewing the filter with my hands or a oil filter wrench but with an ion it's right under the hood. Well, after I push fresh oil in I realised I didn't have a large enough socket to get it off. When I pick one up, can I take out the filter while there is full oil in the car?
Add to mjollnir79's Reputation
Rate the quality of this post and help mjollnir79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjollnir79 is offline   Reply With Quote
Old 06-26-2018, 02:52 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: New oil, old filter, can I replace the filter if there's oil in the car?
Originally Posted by mjollnir79 View Post
Hello everyone.
Yes, you can replace the filter after changing the oil. You'll lose very little oil - especially if you let the engine sit for a while beforehand.
If you plan to keep the car any significant amount of time, you should consider buying the special shallow socket for the oil filter cap. A regular 32mm socket is far too large and won't work because the intake manifold prevents it from being placed squarely on the oil filter lid. You can find the special socket at most auto parts stores for under $10.
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 192K miles
2018 Chrysler Pacifica Touring L 31K miles
Add to ruley73's Reputation
Old 06-27-2018, 11:09 AM   #3
02 LW300
02 LW300 is just really nice02 LW300 is just really nice02 LW300 is just really nice02 LW300 is just really nice
02 LW300's Avatar
Next time change the filter first, a small amount of dirty oil drains into the sump when you remove the filter. The special socket is a good idea.
Add to 02 LW300's Reputation
Old 06-27-2018, 07:51 PM   #4
If your oil filter cap is on top of the filter housing as shown in the drawing below, yes you can replace the oil filter whether the engine has oil in it or not.
Old 06-27-2018, 08:48 PM   #5
The socket I purchased from O'Reilly's is found in the link below. The hex on the oil filter cap is large - 32mm. Although the socket looks like as if it's an impact type don't let it's appearance fool you, it is not.
https://www.lislecorp.com/specialty-...r-gm-2-2l-32mm
FWIW, I remove the filter while the oil is draining. The cap and housing are then cleaned of the old oil remnant prior to to installing the new filter and o-ring seal. There is no need to wait until the engine oil drain plug is reinstalled to do those things.
307,000 miles - Holy canolli!
Add to pierrot's Reputation
How to replace Fuel Filter? Taipans Vue Tech 10 03-06-2010 10:13 AM
Should I replace my dryflow filter ? sl2gold S-Series Mods 1 01-31-2008 11:32 PM
How to replace cabin air filter mariee500 Ion Tech 27 12-19-2007 02:05 AM
replace cabin air filter. skdvr Ion General 38 04-17-2006 10:07 AM
When should i replace my transmission filter? Beemish S-Series Tech 9 03-15-2006 11:11 AM
