Old 11-18-2015, 08:22 PM   #1
Meloche1
Meloche1 is on a distinguished road
2002 SC1
Default Passenger front seat belt
Hi ..... this spring, #2 son opened the sunroof, and it hadn't been opened in quite some time, so the drivers side jammed, while the right side moved to the back, putting the sunroof glass on an angle....to make a long story short, I just replaced the sunroof module. Had to take headliner down, so I decided to remove it and recover it. When I took the RF seat shoulder belt off, everything all went flying ( washers, brass bushing and a spring), now I can't figure what order it goes back together. Has anyone had theirs off? No help in the service guide ( I work at a GM Dealer)
Add to Meloche1's Reputation
Rate the quality of this post and help Meloche1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Meloche1 is offline   Reply With Quote
Old 11-18-2015, 09:10 PM   #2
Default Re: Passenger front seat belt
I never had mine apart, but would think that the assembly shouldn't be hard to figure out, IF you have all the parts.
Probably the bushing goes in first, place the spring on over the bushing then washer(s) on top of that to hold the spring compressed.
If in doubt, gently undo the other side seatbelt and see how it goes together.
Old 11-19-2015, 12:33 AM   #3
You don't "put it back together" (unless you have special tools 99.9% of places "not a seat belt manufacturer" don't have)...you replace the belt with one that isn't a broken pile of plastic. Not too tricky, think it's a T55 on the shoulder attachment and maybe T45's for the lower attachment.
Passenger side seat belt jammed (97 SC2) Starlight S-Series General 3 06-15-2013 11:02 PM
Driver vs. passenger seat belt MJD112379 Aura General 5 04-26-2007 11:25 AM
Front passenger seat hess Outlook General 1 04-21-2007 11:40 AM
1998 SW2 Passenger Seat Belt Help havok S-Series Tech 1 03-08-2007 03:25 PM
Front passenger seat fix? NewCarNewbie Outlook General 0 02-03-2007 01:53 AM
