Old 02-23-2019, 09:30 PM   #1
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
Dizzy Front Drive Shaft Nut Size for Socket
Front Drive Shaft Nut Size for Socket Size
How much trouble is it to remove that nut?
The goal is to be able to yank off the drive shaft on both side to be able to salvage both wheel bearing that are newer on a junk car.
my main worry is to free that nut off and detach the two bolt from the shock and the one from the lower control arm, take off the brake caliper and hopping the CV shaft will free from the bearing and the entire part that hold the wheel bearing/hub assembly will come out free.
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Old 02-24-2019, 03:02 AM   #2
Samtherecordman
Default Re: Front Drive Shaft Nut Size for Socket
Gonna take a guess and say I need 30 mm Socket???
Feels lonely to answer my own question, I swear I can hear crickets !!! LoLLL
Old 02-24-2019, 03:14 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
A replacement nut from Dorman is 30mm. The OEM nut should be the same.
2007 Ion 2 Quad Coupe 5-speed manual 180K miles
2007 Chevy Equinox LT 191K miles
2018 Chrysler Pacifica Touring L 27K miles
Add to ruley73's Reputation
Old 02-27-2019, 06:18 PM   #4
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Good info to have, Iím changing wheel bearings and canít remember the nut size...
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
ďStockĒ is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 02-27-2019, 07:17 PM   #5
Samtherecordman
So I purchased a 30 mm Deep Impact Socket at Princess Auto.
The socket was a wopping $19 , but its Air Gun Rated, that will last a lifetime.
My weapon of choice was my DeWalt 1/2" Impact Gun.
How long it took to get that nut out of there.... less then 10-15 seconds!!!!
It went smoother then buttering my toast in the morning, that is how well it whent!!!!
As fare at the second Bearing I used a Puller, it came out no problem.
As fare as the first Bearing on the driver side, I use Puller, crow bar, hammer, the bible , few curs words, some tequila shots, man I had to shovel the snow out of the car. The first bearing came out into two pieces, the ABS ring felt a part that how bad it was. I also used a 3 Pound Rubber Hammer with some sand in the head. Its really awesome, as you have the weight, but on the moment of impact, it does not bounce and that is really important, not to brake **** up or have it bounce out of control etc!!!!
I used a Propane Torch, as it was -15 C outside with blowing and drifting snow.
Hope I helped you guys in some way and made you smile !!!
May I add, I'm proud of myself, because I did not know how to do it before, it was a learning experience, of course I need to purchase just few extra tools, but it was well worth it!!!
Cheerz !!!
what size socket for drive axle nut??? n2k2baby S-Series Tech 8 11-25-2011 12:36 AM
97 SL2 Crank shaft pulley bolt socket size?. WJ33 S-Series Tech 7 01-12-2009 10:09 AM
Front brake socket size 83trekker S-Series Tech 5 10-16-2008 06:40 PM
Front Right Drive Shaft heathen Vue Tech 2 06-14-2007 10:54 PM
What size socket to remove front rotor? 2000sl2blue S-Series Tech 3 04-02-2002 01:43 PM
