Old 03-12-2023, 01:19 PM   #1
Cavell
Default Align after struts?
Got new struts for my equinox with 120k miles. My vue has 200k. So, I put old equinox struts on vue. They are gm so they are ok quality? I looked online for cross reference and think the swap is ok. Fit wise. I have driven 500miles on vue in last year. Sits mostly. Now I notice a slight drift to left. Struts bolt to knuckle with no adjustment. Just the way it is? Been a long time since I had vue aligned. Bother?
Old 03-18-2023, 09:06 AM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Align after struts?
...I would have it aligned. Also invest in a pair of caster/camber bolts, I believe autozone has them. I had to use them on my 2006 when I put kyb struts in mine. I wiped out a pair of front tires quickly before getting the bolts and alignment .Hope this helps, DC.
Old 03-19-2023, 11:38 AM   #3
Cavell
I use string method to tweak toe. Has worked ok on 1/2 dozen cars. My equinox is perfect. Steering wheel is centered and it tracks straight as an arrow. I thought vue was ok last fall with 2 mismatched front tires. I got 2 newer alloys with great tread and now it drifts. Maybe it’s a tire issue?
File Type: jpeg 8B11957B-34CE-4399-B3E6-F71F0465E1DE.jpeg (42.2 KB, 4 views)
Do you align your car yourself? Recycled Saturn S-Series General 18 09-05-2014 01:06 AM
How Many Times Does It Takes To Align a Car? The Critic S-Series Tech 5 06-30-2009 11:25 AM
To align or not dj1111 S-Series Tech 11 11-30-2008 11:32 PM
Do they HAVE to pop the hood to align a saturn? TIMSPEED S-Series Tech 12 10-12-2006 10:48 PM
Align Trunk Techpriest S-Series Tech 6 08-07-2006 12:16 PM
