Old 03-22-2000, 02:16 PM   #1
CdnSL2
CdnSL2 is on a distinguished road
Default Oil pan gasket leak/replacement
I appear to have an oil pan gasket leak at the passenger side end of the engine and have had the guys at the local oil change place confirm this. Has anyone replaced their oil pan gasket? Is the process particularly difficult (compared to the same job on a small block chevy engine)? I have heard that there is a fair bit of other dissassembly required to get at the pan. Is there a web site somewhere that describes the process in detail?
Thanks for the info,
cdnsl2
Add to CdnSL2's Reputation
Rate the quality of this post and help CdnSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CdnSL2 is offline
Old 03-22-2000, 09:39 PM   #2
sattech
sattech is on a distinguished road
Default
Remove the front pipe converter assy. Remove the bracket between the block and trans. remove the flywheel cover. Remove the harmonic balancer. Remove the pan and reseal.
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
2001 Saturn SL1 oil pan gasket leak jcm22 S-Series Tech 6 09-12-2009 02:05 PM
cam gasket? seal? oil pan leak? have pics SL1commuter S-Series Tech 5 03-11-2009 05:48 PM
Oil pan leak and replacement? mariopalumbo S-Series General 5 05-26-2008 03:49 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 11:25 AM
Burning a Quart of Oil Per 1500 miles: Oil Pan gasket or Rings? TIMSPEED Miscellaneous Tech 4 07-24-2004 08:06 PM
