Old 03-24-2000, 10:48 PM   #1
Slidder
Slidder is on a distinguished road
Default Audio System Capacitors
I'm looking for feedback for those of you that have installed "high end" aftermarket stereo systems. I'm running 4ea (6 1/2S) 3-ways with a 4-channel RF Amp (Power 400a4) and am getting ready to install a 10" Kappa sub with a second RF amp (Punch 250a2 or 360a2, not sure yet) which I'll run bridged. Should I intall a 1/2f cap or just wait and see if the sub dims the lights when it hits? I'm not sure when the right time is to add a cap. Also don't want to waste $100 if I can help it! Thanks in advance.
Add to Slidder's Reputation
Rate the quality of this post and help Slidder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Slidder is offline
Old 03-25-2000, 11:39 AM   #2
Saldana SC2 2K
Saldana SC2 2K will become famous soon enough
Default
I installed a Eclipse 650w X 5 amp and did not add any caps, have no problems. I dont think you have to use any caps.. Just make sure the power cable going to the amp is big enough to handle the power. Also best to use the car frame for gnd then running it from the batt..
Add to Saldana SC2 2K's Reputation
Rate the quality of this post and help Saldana SC2 2K reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saldana SC2 2K is offline
Old 03-25-2000, 11:46 AM   #3
Slidder
Default
Right now I'm running 8-gauge power and ground wire. Still trying to decide whether to go to 4-gauge or not. The ground is hooked to a great place on the underside of the truck on the frame.
Slidder is offline
Old 03-26-2000, 06:31 PM   #4
JasonD
JasonD is on a distinguished road
Default
Allways good to hear other Saturn owners talking about installs.
Caps are not only to prevent headlight dimming they also help the overall quality of sound in your car. They add a more continuous flow of power to your amps. in may case a 1 farad cap gave my subs a much harder "HIT". Caps can also act as relays in the stereo system helping to get rid of some unwanted noise. As for the dimming though, the cap is only a bandage for a much larger problem. If you do get dimming a cap will only mask the real problem, which is a lack of power coming from the alternator. This strain on your alt will eventually lead the alt to fail, as did one of mine(with another nearing failure)
But if you want better sound and harder hitting base then get one. Also look into a new alt(depends on how loud you listen to music) I am near deaf.
Add to JasonD's Reputation
Rate the quality of this post and help JasonD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JasonD is offline
Old 03-26-2000, 06:38 PM   #5
JasonD
Default
Thought I recognized the name. Just came back from Sounddomain. I tried to post a reply to your cap message there, but that message board does not let me post for some reason. There are defeinitely some good posts with good advice over there.
JasonD is offline
Need help with audio system. kenkennings S-Series Mods 24 07-10-2009 05:46 PM
Audio System oonothin Ion Tech 1 06-05-2007 10:24 AM
Audio System spilner Ion Mods 6 05-28-2006 09:20 PM
audio system feej Mods and Performance 20 12-23-2003 02:10 AM
amp capacitors for audio steelers101 Miscellaneous Tech 36 11-02-2003 09:37 PM
