Closed Thread
Old 02-17-2000, 09:20 AM   #1
DVader
DVader is on a distinguished road
Default Procedure to check computer trouble codes?
What is the procedure to check computer trouble codes? Is there a reference (internet, manual, etc.) that I can use that also lists what each code means? Thanks!
Add to DVader's Reputation
Rate the quality of this post and help DVader reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DVader is offline
Old 02-17-2000, 11:34 AM   #2
abkaiser
abkaiser will become famous soon enough
Default
DVader, can you even *get* the codes to check? I've been looking around for a diagnostic tool, and the only thing I could find was a trouble code reader that works only on pre-1996 Saturns!
The pre-1996 stuff can be found here:
http://www.westecauto.com/html/tcodes.html
And here:
http://www.obdii.com/
If anyone else has more info on this... Please help! My 1999 Saturn has the (I thought) OBD2-compliant reader, right by my left knee. But I can't find anywhere that sells a reader that works for it!
Andy
Add to abkaiser's Reputation
Rate the quality of this post and help abkaiser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
abkaiser is offline
Old 02-17-2000, 05:51 PM   #3
CdnSL2
CdnSL2 is on a distinguished road
Default Suggested diagnostic checker
I suggest you visit www.autoxray.com. Their products seem to work on all OBD2 compliant cars. I have not used one but am considering the purchase of one of these and have heard a number of people (Camaro and Firebird owners) say that the devices work well.
Add to CdnSL2's Reputation
Rate the quality of this post and help CdnSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CdnSL2 is offline
Old 02-17-2000, 08:41 PM   #4
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
Default
www.jcwhitney.com has a couple of OBDII code readers in their catalog. They have the Autoxray for $330. and they have an actron code reader that is $180
Add to MaxSL2's Reputation
Rate the quality of this post and help MaxSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MaxSL2 is offline
Old 02-17-2000, 08:41 PM   #5
MaxSL2
MaxSL2's Avatar
2003 VUE 2.2L
Default
www.jcwhitney.com has a couple of OBDII code readers in their catalog. They have the Autoxray for $330. and they have an actron code reader that is $180.
MaxSL2 is offline
Old 02-18-2000, 12:42 AM   #6
Saturn Joe
Guest
Posts: n/a
Default
The newer computer is quite indepth. The scan tool used by Saturn dealerships is the Tech 2, Part number 7000081-SAT3... but I think the only way to get one, is to be a dealer with a couple of thousand dollars. As the computer is sent a fault from one of its sensors, it takes a snapshot from all sensors... for example, MPH, engine temp, and so-forth. It's a pretty neat tool, but for the price... well... too much for me! 1999 should be covered under all warranties, plus, most Saturn dealerships are pretty good about letting you watch as they work on your car.
Add to Saturn Joe's Reputation
Rate the quality of this post and help Saturn Joe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Closed Thread
Cannot get codes from computer arusk76 L-Series Tech 6 01-09-2010 08:52 PM
computer relearn procedure (how to) iacv claude thibault S-Series Tech 4 01-24-2009 10:04 AM
Trouble with Transmission Trouble Codes Toaster_Man S-Series Tech 0 05-22-2008 07:32 PM
computer codes whiteb L-Series Tech 6 04-18-2007 03:14 PM
Looking to buy trouble code computer Mobster S-Series Tech 14 02-06-2007 04:22 PM
