Closed Thread
Old 03-19-2000, 10:15 PM   #1
greg99
greg99 is on a distinguished road
Default Need Help on Head Gasket Install
Has anyone replaced the upper head gasket on a 93SL? Mines leaking and needs replaced. Should i drain the oil, disconnect the pcv valve and take out those two torx bits. Is it more complicated than that? Also what is a good gasket to get and whats the part number?
thanks,
greg
Add to greg99's Reputation
Rate the quality of this post and help greg99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greg99 is offline
Old 03-20-2000, 08:34 PM   #2
Will
Will is on a distinguished road
Default
Hi Greg, I'm guessing that you meen the camcover gasket. I't not that difficult a job if your carefull. If you don't have much mechanical background I'd suggest your local saturn retailer. If your doing it yourself use the Saturn gasket-it's the best you will find. You are correct about the two torx bolts You don't have to drain the oil though. If you do it be very carefull that you clean the old gasket off very well then glue the new gasket to the camcover and install to the engine. Torgue the bolts to 22ft pounds. If your not comfprtable with this Labor at a Saturn retailer might run you about $50.00-$70.00
Add to Will's Reputation
Rate the quality of this post and help Will reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Will is offline
Closed Thread
coolant leak...head gasket, cracked head, or water pump? BRIAN41920 S-Series Tech 13 01-11-2013 03:18 PM
SOHC Alternator bracket oil puddle - head or head gasket? comanche S-Series Tech 10 09-28-2009 04:42 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 02:42 AM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 09:08 PM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 03:26 AM
