Old 10-06-2019, 08:03 PM   #1
Psycho
Psycho is on a distinguished road
1998 SL
Default Thumping noise in front end
I Have a thumping noise in my front end when I go over bumps I just changed out my struts on both sides its not as loud but its still there. I have new lower control arms, new outer tie rod ends, and now new strut assemblies. Only other thing I can think to change is my wheel bearing. Any ideas?
Thanks in advance
Psycho is offline   Reply With Quote
Old 10-06-2019, 09:43 PM   #2
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Default Re: Thumping noise in front end
Just had this issue and it turned out to be my splash shield...the retaining clip/hook part broke so I installed a new hole and fastener and that has since done the trick. I'd see if that was loose if I was you. Also check your stabilizer bar bushings and the bar itself. Good luck!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2007 Subaru Forester LL Bean Edition
Previous:
2008 Honda Accord EX-L 2.4
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 10-07-2019, 08:49 AM   #3
trottida
trottida's Avatar
Could be the sway bar to engine cradle bushings. The OEM part number is 21011235 and they are only about $12 from RockAuto.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 10-07-2019, 08:32 PM   #4
Psycho
1998 SL
@jpags 729: splash shield? Are u talking about the plastic peace under the front of the car?
Thank you all for the info I will change those check on those bushings.
Old 10-07-2019, 09:06 PM   #5
jpags729
jpags729's Avatar
I meant the splash shield on the sides that you see when you remove the tire. Basically the plastic cover that covers the transmission on the drivers side and on the passengers side the plastic cover that you remove when reaching for the oil filter. They hook into another plastic piece and on my the plastic hook portion broke leaving it hanging a little causing noise.
Current:
Previous:
Old 10-08-2019, 08:25 AM   #6
toggenburg
toggenburg's Avatar
Drill holes and secure with black tie-wraps.
Old 10-09-2019, 11:28 AM   #7
Psycho
1998 SL
I did that to the bumper on the drivers side
Old 10-09-2019, 03:27 PM   #8
Highmile
Highmile's Avatar
Check your motor mounts
Highmile
'95 SL1 694k and counting
Old 10-09-2019, 04:48 PM   #9
onlinebiker
They haven't found Jimmy Hoffa yet - so that's a possibility.....
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-09-2019, 06:01 PM   #10
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
Hoffa was in Colorado?
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Old 10-14-2019, 10:16 PM   #11
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
You probably need strut bearings. That's the plate on top of the spring that the strut goes through and gets the big nut screwed on the treads on top of the strut to hold it on. There's a bearing in there that allows the strut to rotate when you steer the wheels left to right and back.
This bearing "plate" then goes up in the body of the car, and has three nuts in the engine compartment that hold it up inside the wheel well. Those 3 nuts are where one bolts an aftermarket strut-tower brace to.
They should have been changed when you changed the struts. Last I checked, they were about $60 each. And you have to disassemble the strut assembly to change them!
Be diligent about your testing, and you can probably determine that you might only need one. Hit bumps / potholes with only the left front wheel, then only the right wheel. Faster / slower. See which one causes the noise, and replace that one.
My car only needed the right-side one (They're both the same).
PrestonIII is offline   Reply With Quote
Thumping noise left front end bigwillie1957 L-Series General 6 11-30-2013 03:48 AM
thumping noise..... 95sc2guy S-Series General 4 04-11-2012 11:09 PM
08 Vue XR Front End Knocking/Thumping Noise johnp3205 2008 Vue 3 01-15-2009 11:15 AM
Right Front Thumping Noise shadow0064 S-Series General 2 03-11-2006 01:13 PM
99 SL1 Thumping Noise Mork S-Series Tech 1 10-25-2004 08:17 PM
