Old 03-30-2014, 10:58 AM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default What is the difference between the 3 types of brake pads
What pads are good to use? There are 3 grades available ceramic, semi-metallic and organic. What is the difference between the 3? I know semi-metallic, there will be a lot of brake dust versus ceramic but what else is the difference between using the 3 types? Are all 3 made just about with the same material? Of the 3, which pads are soft and hard?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 03-30-2014, 12:08 PM   #2
Default Re: What is the difference between the 3 types of brake pads
The system was designed for ceramic. You get much longer pad and rotor service life and minimal dust.
I replaced the front brake pads today using ceramic pads SC Saturn Owner Ion General 12 04-18-2018 03:51 PM
150,000 km on original brake pads, then replaced pads & rotors dontbreakonme Ion Tech 1 03-28-2012 02:06 PM
Inside brake pads worn worse than outside Pads Vue Daddy Vue Tech 7 10-27-2009 07:17 PM
What is difference of these two pads? jing L-Series Tech 1 07-26-2007 02:36 AM
different brake types on left and right Zorak S-Series Tech 5 04-07-2005 08:22 PM
