Old 01-23-2014, 11:20 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Is there a way to test if the clutch is worn out?
My friend is going to look at a 95 SL2 5 speed with 125k. Is there a test to determine if the clutch is worn out? Like putting the car in 4th or 5th gear?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 01-23-2014, 11:27 PM   #2
stovetop1
stovetop1 has a spectacular aura aboutstovetop1 has a spectacular aura about
Default Re: Is there a way to test if the clutch is worn out?
gas it good at 55 to 60mph if it slips constantly there its prob bad
Add to stovetop1's Reputation
Rate the quality of this post and help stovetop1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stovetop1 is offline   Reply With Quote
Old 01-23-2014, 11:40 PM   #3
SL19302
SL19302's Avatar
2002 SL1
Put the car into 2nd gear and apply the Park Brake, Dump the clutch it should stall instantly if the clutch is good, If the engine does not die out right away or even in worse cases continues to idle with the clutch engaged the clutch is bad.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 01-23-2014, 11:44 PM   #4
anmasher
anmasher's Avatar
WOT, 5th gear, ~55MPH, hills. Any slippage indicates a problem.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-24-2014, 12:14 AM   #5
Signmaster
Since it's not his car yet....
Select 2nd gear from a standstill.
Floor it and let it bounce off the rev limiter for a couple seconds to scare the crap out of the current owner.
Dump the clutch.
Note any slip.
Usually the WOT in a higher gear will find the slip if it's there. Uphill is even better if you have a steep hill.
Old 01-24-2014, 11:01 PM   #6
Upstate Saturn
Upstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really nice
Upstate Saturn's Avatar
2001 SL2
What does WOT stand for?
Add to Upstate Saturn's Reputation
Rate the quality of this post and help Upstate Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Upstate Saturn is offline   Reply With Quote
Old 01-24-2014, 11:05 PM   #7
anmasher
anmasher's Avatar
Wide Open Throttle. The PCM (Powertrain Control Module) greatly enriches the mixture and you produce max torque at WOT.
Old 01-24-2014, 11:05 PM   #8
SL19302
SL19302's Avatar
2002 SL1
Wot= wide open throttle.....
CHECK YOUR OIL!
SC1 clutch slave cylinder stiff wire travel test giantflaw S-Series General 14 06-12-2014 03:06 PM
Used Parts - How can I tell how worn a clutch & pressure plate are? cheapybob S-Series Tech 22 12-03-2011 06:14 PM
Key worn out DonP S-Series General 8 02-20-2011 06:23 PM
worn out key Xanadu S-Series Tech 5 07-04-2006 11:17 PM
65kmiles, worn clutch =new flywheel? LI 350 Mods and Performance 2 04-23-2002 03:30 PM
