Old 10-03-2013, 09:45 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Can a vacuum leak cause a misfire?
I'm wondering, can a vacuum leak cause a misfire?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 10-03-2013, 10:06 PM   #2
anmasher
anmasher's Avatar
Default Re: Can a vacuum leak cause a misfire?
Yes, depending.
For example, 3rd gen Sx1's have a vacuum leak at cylinder #1 in the intake manifold gasket. It typically presents itself as a cylinder #1 misfire.
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-03-2013, 10:11 PM   #3
mecanik1
mecanik1 is on a distinguished road
it would depend on where the leak is- emission or evap systems.i would rule out ignition system 1st and check timing,then test egr valve, pcv valve and hoses.if everything checks out spray brake cleaner or throttle body cleaner around intake and throttle body
Add to mecanik1's Reputation
Rate the quality of this post and help mecanik1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mecanik1 is offline   Reply With Quote
Vacuum Leak? trhoades69 S-Series General 11 05-16-2006 01:43 AM
Vacuum leak on my SL2? Marshall S-Series General 3 02-13-2006 01:06 PM
vacuum leak? saturnsctwo S-Series General 6 12-12-2005 11:03 AM
possible vacuum leak? 30pack S-Series Tech 5 09-20-2004 10:52 PM
Vacuum Leak? ym42 S-Series Tech 9 02-29-2004 10:32 PM
