Old 12-10-2012, 01:01 AM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Is it ok to use 10W30 all year round?
I live in Chicago and wondering if it is ok to use 10W30 all year round even when the temperature gets into the single digits? My Saturn does burn a little oil.
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 12-10-2012, 08:41 AM   #2
Default Re: Is it ok to use 10W30 all year round?
No, it is not. The first number only relates to the low temperature characteristics of the oil. All xW-30 oils appear to be a 30 weight oil at 70F and above oil temperature.
Old 12-10-2012, 09:41 AM   #3
Gostlrs
Gostlrs is on a distinguished road
1993 SL2
Depends on what your read I guess...
IMO....Just like this article...Any weight is ok..
Just make sure that you have the same weight to top it off.....
http://www.worldsbestoil.ca/which-30-weight-oil.php
Current Rides
2006 Pontiac Grand Prix
1994 Nissan Hardbody
1994 Mercury Capri XR2 (#350 of 366 Made)
1993 Saturn SL2
Add to Gostlrs's Reputation
Rate the quality of this post and help Gostlrs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gostlrs is offline   Reply With Quote
Old 12-10-2012, 10:22 AM   #4
You'll be sorry using 10w40: the first number before the 'W' means winter weight and the second number is for summer weight. 5w20/5w30 is recommended for better fuel economy and better winter starting. 5w means lower temperature starting capability and if you use 10w30/10w40 you risk oil turning to a gel that won't allow dead winter starting or a very slow starter because 10w(30) is too thick for winter use (in Illinois). Either stick with 5w30 or try 5w40. The 5w will allow very cold weather starting. A thicker 30 or 40 (5w30/5w40) may help with lowering oil consumption but is not guaranteed.
Old 12-10-2012, 10:43 AM   #5
PlasticCarsRock
PlasticCarsRock is a jewel in the roughPlasticCarsRock is a jewel in the roughPlasticCarsRock is a jewel in the rough
PlasticCarsRock's Avatar
I wouldn't recommend it. You could run 5W-30 all year round, though.
At operating temperature, 5W-30 and 10W-30 are virtually identical. That's what the 30 means (the W part is irrelevant at operating temperature).
The W part refers only to how much thicker the oil gets at cold temperatures. 5W-30 oil will behave like 5 weight oil at cold temperatures (which is still far thicker than 30 weight at operating temperature, and far thicker than you need). Likewise, 10W-30 oil will behave like a 10 weight oil at cold temperatures (in other words, becoming much thicker than the 5W-30 oil, although still not nearly as thick as a straight 30 weight oil).
Even with 0W-30, the oil is far thicker than necessary, at cold temperatures, and virtually identical to 5W-30 or 10W-30 at operating temperature, which is why oil manufacturers claim it is compatible with any engine that requires 5W-30 oil.
In other words, using 10W-30 in the winter will make the oil too thick when cold, and will have no benefit once it warms up.
As far as I know, the only benefit of 10W-30 over 5W-30 was cost and availability, but 5W-30 is typically the same price, now, and is readily available.
High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
Add to PlasticCarsRock's Reputation
Rate the quality of this post and help PlasticCarsRock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PlasticCarsRock is offline   Reply With Quote
Old 12-10-2012, 11:03 AM   #6
Recycled Saturn
Recycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura aboutRecycled Saturn has a spectacular aura about
Recycled Saturn's Avatar
I've been using 10w-30 conventional for almost three winters now with temps as low as 20 below and have had no problems. Always fires up right away.
Just saying...
1998 SL2-AMR Strut Bar, AEM CAI, and 119,XXX
Add to Recycled Saturn's Reputation
Rate the quality of this post and help Recycled Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Recycled Saturn is offline   Reply With Quote
Old 12-10-2012, 11:03 AM   #7
Spaghettiohead
Spaghettiohead is on a distinguished road
1999 SC2
I had my SC2 in Chicago for a couple winters and was using 10W-30. Never found any ill-effects, but neither did I find any gain by using the thicker oil. Stick with 5W-30.
Add to Spaghettiohead's Reputation
Rate the quality of this post and help Spaghettiohead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spaghettiohead is offline   Reply With Quote
Old 12-10-2012, 11:20 AM   #8
Keep in mind what happens when you are below 100F with these oils. The 10w is too thick to flow adequately cold.
Old 12-10-2012, 12:51 PM   #9
Nicktheviperman
Nicktheviperman is on a distinguished road
Nicktheviperman's Avatar
2002 SL1
its in the manual for all tempretaures and on the oil cap of ur s series
Add to Nicktheviperman's Reputation
Rate the quality of this post and help Nicktheviperman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nicktheviperman is offline   Reply With Quote
Old 12-10-2012, 03:45 PM   #10
You won't see or feel the accelerated wear for many tens of thousands of miles. Doesn't mean it isn't there.
Since 5w30 costs the same as 10w30, why not use 5w30? If you get the 10w30 for free for some reason, run that from the spring until late fall. I've been running 10w30 all summer, next change in a couple of weeks will be back to 5w30
Old 12-10-2012, 04:00 PM   #11
Over 90% of all internal wear occurs at starup. Using an excessively high cold viscosity oil just accelerates this wear. As 0w-30 oil was not available when the Saturn spec was initially drawn up it would be preferred for low temp service.
Old 12-10-2012, 04:14 PM   #12
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
I'd be using a 5 or 0w30 in Chicago if it were me.
I ran 0w30 and 5w30 in the winter on my S-series always.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is offline   Reply With Quote
Old 12-13-2012, 06:14 PM   #13
bobbyrae
bobbyrae has a spectacular aura aboutbobbyrae has a spectacular aura about
1993 SL2
One thing to keep in mind is how these multi-viscosity oils work. They start with a base oil (the first number) and then add viscosity enhancers sufficient to achieve the second number at higher temps. The viscosity enhancers are polymers that are rolled up at low temps, and then unroll to become long strings at high temps. 5w-40 has more viscosity enhancers added than 10w-30.
The trouble with these polymers is that they burn more easily than oil, creating carbon. For this reason, I try to buy oil with the smallest difference between the two numbers while at the same time being appropriate for the temps involved.
Bobby Rae
Alameda, CA
1993 SL2 A/T, 80k miles, 22/33/43 mpg
1982 Accord 5-speed, 303k miles, 23/32/40 mpg
Add to bobbyrae's Reputation
Rate the quality of this post and help bobbyrae reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobbyrae is offline   Reply With Quote
10W30 question. 04Pacific Vue Tech 9 12-08-2010 11:22 PM
accidently bought some SC/CC 10w30 oil - ok? WAB S-Series General 9 04-07-2010 03:17 PM
interior fan blows hot air year round zigmondjmoline S-Series Tech 1 04-14-2008 09:15 PM
Oil leak with 5w30 but not 10w30? BullyCanadian S-Series General 3 03-16-2006 06:58 PM
Difference between 10w30 and SAE 30? turbobuick33 S-Series General 3 09-21-2005 10:58 PM
