Old 11-16-2013, 08:29 PM   #1
XDoXWhatX
XDoXWhatX is on a distinguished road
Dizzy No start unless gas pedal floored wont stay running when rpm dropes below 2000
Recently did an engine swap my previous engine had a spun bearing. used a block out of a 1996 sc2 and the head out of my 2002 had to make 1 modification to a sensor not sure which 1 it was. everything else matched up fine no vacuum leaks that I can find plugs and wires fine double checked timing and still no luck any ideas?
also to note rpms top out ant 4000 and if car is cold it will start once fine without using gas pedal after that it has to cool down.
Add to XDoXWhatX's Reputation
Rate the quality of this post and help XDoXWhatX reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
XDoXWhatX is offline   Reply With Quote
Old 11-16-2013, 08:49 PM   #2
Default Re: No start unless gas pedal floored wont stay running when rpm dropes below 2000
What model/year of car and what year and model of PCM? Figure out which sensor you modified/changed and exactly what did you do to it.
Old 11-16-2013, 08:52 PM   #3
XDoXWhatX
I found out it was the knock sensor the old 1 didn't match up had 1 wire mine has 2 and a different bolt size so I bored it out to match the correct size did that damage it? and I have a 2002 sl2
Old 11-16-2013, 09:00 PM   #4
XDoXWhatX
if you look on autozone I think you might be able to see the difference between the 96 knock sensor and the 2001 and srry its a 2001 not 2002
Old 11-16-2013, 09:17 PM   #5
XDoXWhatX
and how do I check pcm model number I know its the pcm that is right next to battery tray
Old 11-16-2013, 09:20 PM   #6
If you did not change it then it is the same as your car. Your problem is either the TPS or the ECTS most likely. Have you done anything to the ECTS? Did you ever replace it ? Is the connector clean? Did you disconnect the PCM when doing this bottom end swap?
NOOB-2000 ls2 cranks but wont stay running please help glassheadlights L-Series Tech 3 05-05-2012 05:43 PM
saturn wont stay running!!! twincharged S-Series General 10 03-20-2012 10:23 PM
97 saturn wont stay running countrygirlcna S-Series Tech 3 02-25-2011 08:23 PM
2000 Ls2 was running fine... now wont start!! Will crank, not turn over... dustinv123 L-Series Tech 5 12-02-2009 01:28 AM
car wont stay running pkuptrk Miscellaneous Tech 1 01-04-2003 11:06 PM
