#1 |
![]() Join Date: Dec 2010
I think I just drained the battery by starting too much and using too much power, but it can't hurt to ask.
I also had the fan and AC running at full blast the whole time. It clicked once when I turned the key at the last stop, then clicked again on the second turn. It cranked on the third try. This was after it sat for 2 days. Is this a symptom of putting too much on the battery without giving it time to charge up? |
#2 |
![]() ![]() Join Date: Mar 2010
If it otherwise cranks at normal speed, and your headlights are fully bright with the key 'off,' then the problem likely lies within the starter solenoid. You can merely replace the solenoid (which requires removal of the entire starter motor), or you can replace the entire motor. The brushes are likely worn, too. These are special order from NAPA, and they come from Virginia. The brushes and solenoid are likely much cheaper than a new motor, but might not be as convenient.
If you do rebuild the old motor, be sure to clean up all external connections. |
#3 |
Removing the end cap will disclose the condition of the brushes. If they both look like they have plenty of wear left, then you can probably just replace the solenoid and get plenty more miles out of the motor as-is. Perhaps order the brushes now so that they will be handy later. If you by chance agitate or remove the brush holding assembly, be sure to reinsert the phenolic insulators that go between the brushes and the brush tension springs. If these are not put back in place, a direct short will occur through the tensioning springs, and the motor will not work.
#4 |
Would that explain why it occasionally wont start after sitting a couple of days?
#5 |
![]() Join Date: Apr 2009
1995 SW2
Could be starter... just as likely you've got a dead alternator that's just not charging the battery. Go to AutoZone or someplace similar to get your battery tested, just to make sure you don't have a bad one.
On the car with the engine off, your battery should be giving 12 to 12.5 volts from the battery posts. With the engine on, it should be in 13.5-14.5 volt territory. if it's lower than that, chances are your alternator is shot. If it's testing as good, then you've got to look at your starter. Just went through this myself! |
#6 |
The lights dimmed a little bit when I turned the car off, but it was barely perceptible. I'm also pretty sure the alternator is fine because I hear something kicking in when I hold the window button down after it's fully open and when I turn the lights on.
#7 |
1995 SW2
The alternator doesn't kick in... it runs off the drivebelt on the engine. What you're hearing is the relay kicking in to drive the power window motor. And it's totally possible for the battery to have enough juice to operate lights and the windows but not enough to crank the car... especially if the alternator is failing and delivering some charge when the car is on.
You won't really know until you check the voltage on the battery posts with the car on and off. If it's not that or a bad cell in your battery, then it's probably the starter. |
#8 | |
![]() Quote:
The sound I hear is a change in RPM (confirmed by the gauge), not a switch. The battery would have run down months ago when this first started if it were the alternator. Last edited by MKR; 08-26-2011 at 04:54 PM. |
#9 |
It's always on. Your just asking for more from it, so it puts a larger load on the engine. Bigger load & same throttle = lower RPM.
The proper way to fix a S-Series automatic is to replace it with a manual |
#10 |
I'll go and have Advanced Auto check the voltage some time next week. What should I be expecting for prices on a used or new {starter, solenoid, alternator}?
#11 |
1995 SW2
I had to put down about $110 or so for a reman alternator from O'Reilly a couple weeks ago. I had close to this same problem... oddly, I called a shall-not-be-named place that does rebuilds, and they wanted to charge me $165 to rebuild what I already had. I paid the $110 for a reman with a limited lifetime warranty; you'd think it'd be cheaper to rebuild the thing.
Cheapest starter I found on RockAuto.com was $116 for an ACDelco reman starter (part 3361176A). Pick your poison cost-wise I guess! |
Bookmarks |
well i got a new problem named click-click- click-click- click-click- click | sl2solow | S-Series General | 3 | 08-13-2010 10:49 PM |
Not starting. Single click. Now no click | clean93 | S-Series Tech | 4 | 12-03-2008 03:02 PM |
Click, click, click goes the dash! | skid_marque | Vue General | 11 | 05-05-2008 10:26 AM |
"Click, Click, Beep." What is that? | Commando44 | S-Series General | 15 | 11-09-2007 04:59 AM |
