#1 |
![]() Join Date: Jan 2003
I need to replace a SOHC in a 95 SL1. The shop manual outlines a proceedure of removing the cradle and dropping the engine/transmission out the bottom (looks very involved). Can this engine be removed and replaced from the top. If top removal is possible, is it a smart way to go?
Bob |
#2 |
![]() Join Date: Oct 2002
Access to a four post lift is key. Disconnect everything between the engine and car, put jack stands under the subframe, unbolt the subframe, then lift the car up. If you have a cherry picker you can take the motor off the subframe and put the new one on w/o moving the subframe, then all you have to do is lower the car back on it and hook everything back up. My brother has done this to countless Saturns, lemme know if you need help with anything in particular, I can ask him for you.
#3 |
Top. I've done it twice through the top (get trans from donor car, install in mine), and it wasn't too hard.
-Travis |
#4 |
![]() Join Date: Feb 2000
Top.
Ian
http://www.qksltwo.com |
#5 |
![]() Join Date: May 2003
Top if you are capable, with the right tools and such; bottom, if you hesitate and think that you won't suceed with a top lift.
Cause you would be ![]() |
#6 |
Top is way easier!!!
About to do a top install this weekend!!! DOHC |
#7 |
definatly from the top
Bookmarks |
Tool Needed for Petcock Removal, From the Top or Bottom on '01 SL1? | Pitcher | S-Series Tech | 4 | 09-15-2009 10:06 PM |
Out the top or bottom? | thesameguy | S-Series Tech | 43 | 08-29-2009 06:53 PM |
Ring replacement.From Top or Bottom? | LvnInPeace | S-Series Tech | 7 | 04-21-2009 02:02 PM |
L300 Starter Removal - The bottom bolt | L300inlv | L-Series Tech | 1 | 07-30-2008 12:10 PM |
Pull SL2 auto trans out from top or bottom? | RacerX | S-Series Tech | 4 | 12-22-2004 08:15 PM |
