#1 |
![]() Join Date: Aug 2010
can any one tell me what s the best way to remove the water pump from 1996 saturn 16 valve would be the top think but would like a little more of a better mechanic than me to have the choice made for me as only do minor stuff that can get to easily. To me t seems easy to do but not easy to get at. any help thanks and sorry for the eye n my typing don't work except for when I can use the spell check . thanks leave message if you can or here thanks and have a great day.
#2 |
![]() Join Date: Oct 2009
2002 SL1
2008 Astra XE
Remove the top motor mount and raise that side of the engine and the job will be much easier. The hardest part is removing the 3 10mm bolts from the pulley. This is one of the easiest cars for water pump replacement.
#3 |
I have found it's much easier to do the removal of the water pump from the bottom.
After removing the 3 bolts that hold the pulley in place; there are 6 bolts that hold the water pump to the engine block. Removing through the wheel well is much easier. Just from my experience.
Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC |
#4 |
2002 SL1
2008 Astra XE
2ndscout is right , watch the Richpin video and do it that way-I just had a brain cramp and was thinking about replacing the tensioner or idler pulley. I was outside the 15 minute window to modify my post so I'll look like an idiot for eternity.
#5 | |
![]() Quote:
Bobby Rae Alameda, CA 1993 SL2 A/T, 80k miles, 22/33/43 mpg 1982 Accord 5-speed, 303k miles, 23/32/40 mpg |
Bookmarks |
I need help,problems of water pump removal (right now) | 95 BLACK SATURN | S-Series General | 28 | 01-04-2010 07:17 PM |
Water Pump Removal Help!!! | texlnghorn | S-Series General | 6 | 11-11-2005 01:08 PM |
Water Pump Removal | MDSaturnSL2 | S-Series General | 5 | 07-30-2004 10:41 PM |
Need help with a water pump removal. | Flyguy405 | Miscellaneous Tech | 3 | 12-11-2003 02:36 AM |
Engine removal. From top or bottom? | meseville | S-Series Mods | 6 | 05-16-2003 07:19 PM |
