Old 10-21-2005, 12:48 AM   #1
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
Default floor boards rusted at driver seat
What gauge sheet metal should i use for this, im going to get some tomorrow and weld it in, needs to be satisfactory for a 2X3FT section which is right where the frame is. Need to know by 9:00 AM ThAnKs!
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
Add to JS593's Reputation
Rate the quality of this post and help JS593 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JS593 is offline   Reply With Quote
Old 10-21-2005, 04:20 AM   #2
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
Default Re: floor boards rusted at driver seat
16 or 18 gauge will do it. 16 will be easier to weld.
Add to PeteB's Reputation
Rate the quality of this post and help PeteB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PeteB is offline   Reply With Quote
Old 10-23-2005, 12:17 AM   #3
JS593
JS593's Avatar
1992 SL1
Ripped off the carpet today, and it doenst look good, half the driver side is so badly rusted out, i dont know if i can repalce it, the cross members the boards sit on are gone, there is nothing left of them. I tried to find out any way i can put some new straps on or anything, and it looks like the car is gonna go back to saturn, i want them to look at it, because i think this should NOT have happend so early.... this has to be something else as a problem. The rust went right up from the firewall straight down the driver seat, and now i need a new driver seat because i had to cut one of the frame peices to get to it. I have seen K cars in better condition then this, and it looks like the rust has caused about 10 years of damage, which leads me to believe it was a problem in the firewall or soemthing else close to it leaking. I will return tomorrow with some pictures of the damage.
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 10-23-2005, 01:03 PM   #4
JS593
JS593's Avatar
1992 SL1
I am aslo just kinda curious, When i started cleaning up the metal and rust bits, i show no kind of subframe or anything for the floor, should there be metal straps everwhere to keep it in order? Because if there is supposed to be, then it looks like im getting some other work done... :S
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 10-23-2005, 01:18 PM   #5
JS593
JS593's Avatar
1992 SL1
here is the picture with the most detail and the clearest one as well. This is just a chunk of whats wrong...
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 10-27-2005, 11:16 AM   #6
JS593
JS593's Avatar
1992 SL1
Well, i have both some good news, and soem sad, and unexpected news. Last night around 9:00, we were on the last weld and last panel for the floor boards, ready to giv'r and it looks like the fuel return air lines are toast. We pulled out the hose and the fire extinguisher, and it looks like it was just a rubber hose, but we dont know for sure. I am not sure about the damage that was done to the car, but i will know in about an hour after i get my work cloths on. If anyone can spread some light on the situation here, it would be fantastic. or it looks like im going to be moving over to a 1987 Toyota Corolla SR5 RWD CARB 1.8 with a bit of body work to do.
Thanks in advance,
Dan
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Old 10-27-2005, 12:53 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
Whats the story behind this car? Almost looks like it had been sitting in water for a period of time.
Also, I have a 1995 SL2 that is just the bare spaceframe. If you need a reference pics, let me know.
Old 10-27-2005, 02:19 PM   #8
JS593
JS593's Avatar
1992 SL1
WEll, the panels are already welded on now, may i add, well done (thanks to my dad :P) but fromwhat it sounds like, the drain plugs sealed totally, one should have been left open, and there should have been a hole leading to the frame, then the hole in the frame outside for some circulation, there was just holes, but now since the last weld, all my fuel lines bursted into flames, im going to just add some new peices and see if it works, because it is well over 400$ to get them replaced.
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
Wet floor boards, is sunroof drain lines the problem? k1hog S-Series Tech 3 09-08-2009 09:15 AM
Water on floor boards oldguard L-Series General 2 06-12-2008 08:17 AM
Rusted Floor Repair gfreek1 S-Series Tech 11 11-24-2007 10:35 PM
Floor boards in the Cargo area bend lucky64 Vue Tech 2 05-07-2005 09:12 PM
anybody else have wet floor boards? texan Vue General 7 08-05-2003 07:23 AM
