Old 07-26-2003, 11:22 PM   #1
silverblue02
silverblue02 is on a distinguished road
Default throttle body
What horsepower gain would I see with stock intake coupled to a bigger throttle body? Would I see less fuel consumption? Feel free to tell me all about it.
Add to silverblue02's Reputation
Rate the quality of this post and help silverblue02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblue02 is offline
Old 07-27-2003, 12:17 AM   #2
amazinghl
Default
not much. probably under 1hp.
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 07-27-2003, 01:15 AM   #3
wolfman
wolfman's Avatar
Default
Generally anything that increases the power output of an engine will also result in a DECREASE in fuel economy (assuming the engine is properly tuned) In order for an engine to put out more power it simply has to use more fuel.
Add to wolfman's Reputation
wolfman is offline
Old 07-29-2003, 12:25 PM   #4
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
Exhaust is a better way to go for the time being. Once you've opened things up (from the exhaust manifold on back), then it makes more sense to get a throttle body.
Many of your mods, including your intake, will actually increase your gas mileage. But, this only works if you aren't mashing your right foot all the time. As Wolfman pointed out, performance is a trade off for economy. Hard acceleration will use more gas and ultimately lower your MPG.
Add to SLeepr's Reputation
Rate the quality of this post and help SLeepr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLeepr is offline
Old 08-17-2003, 02:20 AM   #5
Wayne123455
Wayne123455 is on a distinguished road
Default
I put a bigger throttle body on the one sps sells and I found the horsepower increased dramaticly. I also was told by 2 big exhaust dealers here in Ontario that changing just the exhaust doesn`t do much becauseof all the bends in the pipes. Unless you modify the path of the pipe. They said the straight thru low restriction muffler does alot and it does from experience.
Also changing the air intake and the the throttle body really makes a differnce.
I didn`t find much difference in mileage from one to the other but a big differennce in performance.
Add to Wayne123455's Reputation
Rate the quality of this post and help Wayne123455 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wayne123455 is offline
Old 08-17-2003, 03:07 AM   #6
never2fast
never2fast is on a distinguished road
Default
I changed my throttle body and exhaust all at the same time. It was a huge difference. Also my gas mileage went up too. I easily get 33mpg with my automatic with lots of freeway driving. Before the change it was at about 30mpg. When I changed all that stuff I was ready to accept the fact my mileage would go down, but it went up. It is a nice bonus.
Add to never2fast's Reputation
Rate the quality of this post and help never2fast reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
never2fast is offline
Old 08-17-2003, 04:15 PM   #7
silverblue02
Default
Intersting.........!!!
Throttle body MikeNW S-Series Tech 4 08-17-2009 10:53 PM
Throttle Body quiksc2 S-Series Mods 15 02-04-2007 10:35 PM
Throttle sticks - not throttle body - help! dannysm213 S-Series Tech 2 12-10-2006 05:20 PM
throttle body how far? irondiezl3 S-Series Tech 1 11-12-2006 10:40 PM
New Throttle Body sc1sohc Mods and Performance 9 12-06-2003 03:30 AM
