Old 02-13-2007, 11:58 AM   #1
jedi1205
jedi1205 is on a distinguished road
Default No reverse lights...
Hi, I have a 1994 SL2 w/ an AT and the reverse lights don't work. I checked the 2 bulbs & they checked out OK. I checked the fuse & it was blown. I put a new fuse in & replaced the lights with new ones & they worked. Screwed the taillights back in & the reverse lights still worked, but when I started the car & put it in reverse the fuse blew again? Can anyone please help me. I would greatly appreciate it! Thank you all for your time.
Greg
Add to jedi1205's Reputation
Rate the quality of this post and help jedi1205 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jedi1205 is offline   Reply With Quote
Old 02-13-2007, 02:18 PM   #2
Default Re: No reverse lights...
Welcome. So the reverse lights work with the key in RUN, the tranny selector in R, but the engine not yet started? And starting the engine blows the fuse?
Okay, one other test to try -- put the tranny back in Park, install a fresh fuse, start the engine and shut it off again, all WITHOUT shifting into R. THEN check the fuse, and let us know the results.
BTW, you might want to start a new thread in our "S-Series General" or "S-Series Tech" section (but only one place; cross-posting is icky).
Add to madpogue's Reputation
Old 02-13-2007, 02:42 PM   #3
jedi1205
OK, I will try that after work & reply to the post later tonight. I will also post it to one of the S-series threads. Thank you.
no reverse lights trckey2 S-Series Tech 10 09-27-2010 11:21 AM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 10:40 PM
Can anyone help with reverse lights? nothingtolose31 S-Series General 7 05-11-2006 09:01 PM
Reverse Lights Out Already SonataInFSharp Ion General 10 09-19-2004 09:02 PM
Reverse Lights slv01sc2 S-Series Tech 7 04-13-2002 10:16 AM
