Old 04-12-2002, 08:59 AM   #1
slv01sc2
slv01sc2 is on a distinguished road
Idea Reverse Lights
I have a 01 SC2 with reverse lights that don't work. The car is a 5-speed and when I put it in reverse nothing happens. If one light is burned out will the other still work? I wonder what this could be? Is it a short or is there some sort of switch that might be bad? I hope this is not the start of more electical problems to come. Thanks for your help!
Add to slv01sc2's Reputation
Rate the quality of this post and help slv01sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slv01sc2 is offline
Old 04-12-2002, 10:07 AM   #2
bigbird
bigbird is on a distinguished road
bigbird's Avatar
Default
Take it in for warranty service and let us know what the problem was.
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 04-12-2002, 10:31 AM   #3
Qlara
Qlara's Avatar
Roll Eyes
Either both Backup bulbs are out (real lucky!) or the Backup Switch connection is loosen or Reverse switch is fried on your stick tranny......
All under warranty anyway, bring it in with Free car wash too!
Add to Qlara's Reputation
Qlara is offline
Old 04-12-2002, 06:47 PM   #4
slv01sc2
Default
Thanks for everyone's suggestions! I made an appointment for next Friday at my retailer which is 120 miles away. I'll let everyone know what the problem turns out to be.
slv01sc2 is offline
Old 04-12-2002, 09:33 PM   #5
Dizzy
OUCH!!!!!!
120 freaking miles!!!!!!
Are you still under warrenty? Even if you are this is a hell of a long drive for what is likely just a bad switch.
Check the fuse make sure that it's good. Make sure that the bulbs are good. Gain access to the reverse switch, on top of the trans-brown coloured connector, two wires. Disconnect conector, key on, check for power at connector with a test light or multimeter. power to one wire--use a jumper wire to cross the two wires, the reverse lights should work. If they don't, wiring to rear is likely bad. Lights work, use multimeter to check continuity across the switch (trans in reverse), should show continuity. No continuity, switch bad. Most likely you do have a bad switch. Do the checks to make sure. If the switch is bad see if the Saturn store will work with you and send you a replacement and work out the paper work some how. If not then try local or pay then to send you one, it's not expensive and if you can do all the checks then you should be able to use a 7/8 wrench to change the thing.
Add to ssicarman's Reputation
ssicarman is offline
Old 04-13-2002, 03:35 AM   #6
Qlara
Qlara's Avatar
Dizzy
120 miles away?!?! I'd say OUCH too!
How did you get to that dealer to buy the new Saturn at first place? 120 miles is like cross-state driving......
Qlara is offline
Old 04-13-2002, 10:04 AM   #7
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default
My nearest retailer is about 70 miles away. Been there three times. Once to test drive my car, another to buy it, and the last time to get a new fuel pump under warranty.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline
Old 04-13-2002, 10:16 AM   #8
Galileo
Galileo is on a distinguished road
Galileo's Avatar
2007 AURA XE
Default Lucky
Wow! :o: Not to rub it in your face but I have one retailer in my small city and another 4 facilities within a half hour to forty-five minute drive. You must really like Saturn!
Beautiful People First~
Add to Galileo's Reputation
Rate the quality of this post and help Galileo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Galileo is offline
no reverse lights trckey2 S-Series Tech 10 09-27-2010 11:21 AM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 10:40 PM
No reverse lights... jedi1205 S-Series Tech 2 02-13-2007 02:42 PM
Can anyone help with reverse lights? nothingtolose31 S-Series General 7 05-11-2006 09:01 PM
Reverse Lights Out Already SonataInFSharp Ion General 10 09-19-2004 09:02 PM
