Old 11-22-2012, 04:39 PM   #1
Junkfood
Junkfood will become famous soon enoughJunkfood will become famous soon enough
Junkfood's Avatar
2004 L-Series 3.0L Sedan
Question Lazy Seatbelt Retractor
The seatbelt retractor, on the driver's side, of my 2001 L300 is functioning slowly, or at times not at all. How do I access this retractor and can it be cleaned or repaired?
Gary Callahan
Beaverton, Oregon
2004 L300
V6 Get-up and Go!
Add to Junkfood's Reputation
Rate the quality of this post and help Junkfood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Junkfood is offline   Reply With Quote
Old 11-23-2012, 12:50 PM   #2
64waves
64waves has a spectacular aura about64waves has a spectacular aura about64waves has a spectacular aura about
2000 L-Series 3.0L Sedan
Default Re: Lazy Seatbelt Retractor
I second the motion on this one, both my cars have this issue. If there is something that can be done it would be great.
Add to 64waves's Reputation
Rate the quality of this post and help 64waves reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
64waves is offline   Reply With Quote
Old 11-23-2012, 01:28 PM   #3
Did you try Googling 'repairing seat belt retractor' or some similar key words? Google came back with 713,000 results..............................
Just remember that inertia belts operate on the principle of a body that won't decelerate while the car stops during an emergency braking event. Sudden car deceleration as in a crash still allows a body to ".......remain in motion" and the seat belt reacts when a body tries to maintain forward motion, pulling the belt out immediately. This sudden acceleration of the seat belt from the retractor engages a mechanism to halt the belt from further travel, restraining the body from destroying the steering wheel, dashboard, windshield, etc.. Hopefully an airbag is deployed at this time to cushion the head from meeting the steering wheel or windshield.
Be wary when making adjustments and test the belt before and afterwards. The simple test for inertia belts; yank the seat belt with a strong tug as quickly as possible (very fast). If done correctly, you're duplicating a body continuing to stay in motion as the retractor reacts and stops the belt from traveling. A second method would be to pull out the belt as if getting ready to buckle up but allow the belt to retract; allow the belt to develop slack and then quickly yank hard - this should lock the belt immediately, restraining belt travel. These two methods are the easiest way to test belt retractors as if in a speed related accident. Any adjustments made to the belt retractor should be tested afterwards to ensure the inertia mechanism isn't compromised - failure to heed this warning can or may result in disabling the inertia feature. At worst, inadvertently disabling this safety feature can result in no belt lock up during sudden stops at speed with the belt continually being reeled out - the body will continue to travel into whatever it hits..................instead of having the inertia mechanism lock the belt from further travel.
Just a heads up for anyone thinking seat belt repairs is a DIY thing without thinking of the negative consequences. The best case scenario is spring adjustment goes without issues and the retractor works as good as new with the inertia feature intact.
Old 10-15-2018, 04:56 AM   #4
Junkfood
Junkfood's Avatar
Here is a YouTube video all about this slow seatbelt retractor issue: https://youtu.be/8XL8QbooM84
Gary Callahan
Beaverton, Oregon
2004 L300
V6 Get-up and Go!
Old 10-15-2018, 12:17 PM   #5
Did cleaning your seatbelt correct the problem?
Old 10-15-2018, 10:07 PM   #6
Hmm...Looking at post #3 it would appear that Junkfood revived an otherwise inactive thread. If the information added is good then it's always useful.
316,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 10-17-2018, 04:51 AM   #7
L200StillKickn
L200StillKickn has a spectacular aura aboutL200StillKickn has a spectacular aura aboutL200StillKickn has a spectacular aura about
2002 L-Series 2.2L Sedan
It could be just really dirty from years of use. Mine use to do that until I pulled them all the way out as far as possible, did something to prevent them from retracting, soaked them each in a bucket of soapy water, then scrubbed and rinsed, using a towel after to get most of the water out of the straps. I left them pulled out while to dry. They looked & smelled great & work fine now.
Add to L200StillKickn's Reputation
Rate the quality of this post and help L200StillKickn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L200StillKickn is offline   Reply With Quote
SC2 Lazy Eyes. timworthen S-Series Mods 4 02-16-2007 03:11 PM
Being Lazy: Need help with A/C problem fatherof5 S-Series Tech 2 06-08-2006 02:44 AM
Lazy locks redrings L-Series Tech 4 02-22-2006 07:44 PM
"Lazy" seat belt retractor Bill Murray S-Series Tech 10 11-10-2004 12:18 PM
