Old 09-23-2018, 11:47 PM   #1
claybear
claybear is on a distinguished road
Default Needing Fuel Tank Shield
Anyone know of a good salvage yard source or possibly new part source for the fuel tank shield for a 2002 L-series? I'm replacing the fuel pump (and brake lines and parking brake cable and muffler) and cannot reuse the shield removed from my LW200. Image attached should be obvious. Anyway, through email I've reached out to several salvage yards in AZ and NM but need to follow up with phone call because none have replied - no surprise. Just trying to keep this vehicle going for two more years to get my daughter through high school. We've owned it since new but WI winters take their toll. Any tips would be appreciated.
Add to claybear's Reputation
Rate the quality of this post and help claybear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
claybear is offline   Reply With Quote
Old 09-24-2018, 12:37 AM   #2
Default Re: Needing Fuel Tank Shield
claybear, I'd suggest the following:
1) Use an OEM parts website, https://www.gmpartscenter.net/, for example, and compare the shield part numbers between the sedans and wagons. If they use the same number then you'll have a wider number of parts to find. If not, then that "world" of parts available is simply smaller.
2) Use http://www.car-part.com/, a parts website for wrecking yards, to help you find where this shield may be found nearest to you or at other locations around the country.
(3] If you'd like some help beyond this from someone like me in CA then I'd be happy to assist. Send me a private message (p/m) through SaturnFans.)
294,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 09-24-2018, 11:00 AM   #3
Mine looks similar but remains on the car. Still passes NYS vehicle inspection so my guess is as long as the plastic fuel tank remains intact, the shield is just a cover. I removed my muffler heat shield earlier in the year and haven't got around to reinstalling it. My guess is all the mounting holes on the shield rusted thru as it partially fell off while was driving home from local trip to the market, dragging on the street and making a racket. Same thin gauge metal.
Old 09-24-2018, 12:39 PM   #4
floridasl22002
As you live in the rust belt, I suspect all the shields in the JY's near you will be in the same condition.
After we bought my son's 2003 L300 we discovered that although we are in Florida, the car spent some time in the North and came with the no cost option of rust.
When I discovered that I spent some time checking out the underneath and as with yours, the tank shield and muffler heat shield were in a sorry state. We went to a local JY and found a Florida L series and took off the shields and straps. I then cleaned them up and gave them several coats of spray paint. My indo garage fitted them for me. I was under the car at the weekend and the shields + straps are probably the things in the best condition there!!
As for suggestions, I can make only 2; one would be to try and source replacements from a rust free area or to try and fabricate locally that would at least do the shielding bit. it doesn't have to be a clone, just something that can protect the tanks.
My son's car was bought for him in HS. He's got 3 year more years at college, so I'm working to try and make it last till he graduates.
Old 09-25-2018, 08:05 PM   #5
Russet
2002 L-Series 3.0L Sedan
I found mine at a junk yard and it was ok little rusted but I sprayed rust treatment and it looks ok now. But I was lucky some others I found were far worse and just like falling apart.
Add to Russet's Reputation
Old 09-25-2018, 08:14 PM   #6
claybear
Thanks all for the replies. Yes, all the salvage yard parts in the upper midwest that I have contacted either have no shields or they are steel dust. Still need to follow up on the AZ and NM yards and should try some other states also that do not use much or any salt on the roads. I do think that all the L series vehicles use the same shield so that helps a little. Only concerned with the tunnels through which the exhaust is routed to protect the tank from the heat. Do not really know how warm the exhaust is at that point but I would rather be overly cautious with my daughter driving the car. The other heat shields are aluminum I think and yes they all corroded around the fastener flanges leaving a disc of aluminum and the same size hole in the shield. SS fender washers should take care of that issue.
Just two more years and we move on to another vehicle. Just two years!
Old 09-26-2018, 08:05 AM   #7
floridasl22002
I found that on the L series at the rear, there are bolts that are welded on at manufacture which allows things like the heat shields to be attached. However I found on my son's a couple had rusted so bad they had just fallen off, so the shield was flapping. My solution with to drill through where the old bolt/stud was and use a SS nut & bolt and like you use a big SS washer to hold the shield on. That plus liberal caulking has worked BUT of course you were are dealing with the prospect of bi-metallic corrosion something I think the designers didn't take into account when attaching aluminum to steel bolts/studs.
Old 10-05-2018, 06:41 PM   #8
claybear
Good news folks! TN came through. I like winter sports but having to work on cars here makes me kind a long for a more southern latitude.
Heat shield for gas tank completely rotted. Vinny L-Series Tech 4 05-21-2013 08:20 AM
Gas tank shield rusted out Oliviar L-Series Tech 2 06-09-2012 02:28 PM
Help When Fuel Gets Below 1/4 Tank... 96SaturnSL1 S-Series General 34 10-03-2008 08:37 PM
Gas Tank Heat Shield dave.sl S-Series Tech 3 04-03-2008 10:24 AM
Fuel Tank? Furshnekedy General Saturn Discussion 3 03-01-2005 10:40 PM
