Old 05-10-2006, 03:47 PM   #1
nothingtolose31
nothingtolose31 is on a distinguished road
nothingtolose31's Avatar
Default Can anyone help with reverse lights?
The reverse lights on my car haven't ever worked since the car has been mine, and just wondering how to go about fixing them. I've checked the bulbs and the fuse and it all looked good. I have a '95 DOHC manual Sc2. Please help...
-Daniel
95 green 5 speed DOHC Saturn Sc2
Add to nothingtolose31's Reputation
Rate the quality of this post and help nothingtolose31 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nothingtolose31 is offline   Reply With Quote
Old 05-10-2006, 03:48 PM   #2
S3aturnR
S3aturnR is a jewel in the roughS3aturnR is a jewel in the roughS3aturnR is a jewel in the rough
S3aturnR's Avatar
1996 SL2
1999 SL1
Default Re: Can anyone help with reverse lights?
it's your reverse gear sensor. located on top of the tranny (behind the battery and WAY down below it). looks small, almost like a s.park plug or o2 sensor. costs about $10 if i remember right...
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
Add to S3aturnR's Reputation
Rate the quality of this post and help S3aturnR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S3aturnR is offline   Reply With Quote
Old 05-10-2006, 04:28 PM   #3
drshivas
drshivas is on a distinguished road
Yep, do a search for "backup switch". I bought mine from saturnparts.net. You can also try fredbeansparts.com.
Add to drshivas's Reputation
Rate the quality of this post and help drshivas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
drshivas is offline   Reply With Quote
Old 05-10-2006, 10:41 PM   #4
wolfman
wolfman's Avatar
Or he could just check my user gallery (by clicking the little camera next to my avatar) for a picture of its location on a actual transaxle...
Add to wolfman's Reputation
Rate the quality of this post and help wolfman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolfman is offline   Reply With Quote
Old 05-10-2006, 11:39 PM   #5
madpogue
1996 SW2
Quick test, when you find it. Disconnect it, and jumper a wire between the terminals on the connector. Turn the key to RUN. Bet a nickel the reverse lights go on, which means the switch is the culprit.
Add to madpogue's Reputation
Old 05-11-2006, 12:50 AM   #6
jjsk8r85
jjsk8r85 is on a distinguished road
jjsk8r85's Avatar
1992 SC
mine's really weird. my reverse lights don't work, but when I pull the switch out and push the "button" in by hand, they light up, but not when the switch is in the trans.
92 SC 5-speed 239k miles
Add to jjsk8r85's Reputation
Rate the quality of this post and help jjsk8r85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjsk8r85 is offline   Reply With Quote
no reverse lights trckey2 S-Series Tech 10 09-27-2010 11:21 AM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 10:40 PM
No reverse lights... jedi1205 S-Series Tech 2 02-13-2007 02:42 PM
Reverse Lights Out Already SonataInFSharp Ion General 10 09-19-2004 09:02 PM
Reverse Lights slv01sc2 S-Series Tech 7 04-13-2002 10:16 AM
