Old 11-22-2005, 12:29 AM   #1
98greenSC2
98greenSC2 is on a distinguished road
98greenSC2's Avatar
Default Shifter still feels sticky, even after new shifter and cables!
I posted a while back that the shifting on my car is rough and balky. It's difficult to get into gear smoothly. I really have to push it into gear. I recently installed new shifter cables and a short shifter. I thought the cables would fix it but I guess not. They still needed to be replaced. I discovered the shifter grommet broke before I even bought the car. Someone repaired it with a short length of PVC pipe and a wire tie.
Could it be the clutch hydraulics? It normally doesn't grind going into gear but once in a while, it will. It'll sometimes shudder like the clutch is grabbing a little when I'm at a stop and I have the clutch pressed in and in gear. Would it also make the shifting difficult? I don't think the hydraulics were replaced when I had the clutch done or after I blew the diff pin.
http://members.cardomain.com/stdmtn11
15.59 @ 87.1 quarter mile
1998 Saturn SC2 *sold* What have I done!?
Add to 98greenSC2's Reputation
Rate the quality of this post and help 98greenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98greenSC2 is offline   Reply With Quote
Old 11-22-2005, 08:17 AM   #2
abe
abe is on a distinguished road
Default Re: Shifter still feels sticky, even after new shifter and cables!
I had the same thing happen to me but I replaced the hydraulics because I thought that was it
As it turned out (because I used a rebuilt clutch when I replaced the clutch) a few fingers were bent on the pressure plate
New clutch fixed the problem for me.
Add to abe's Reputation
Rate the quality of this post and help abe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
abe is offline   Reply With Quote
Old 11-22-2005, 09:57 AM   #3
jdcart
jdcart is on a distinguished road
I have a 97 SC1 with the same problem. I am glad to read the reply about the clutch replacement solving the problem. I seriously believe that the transmission synchronizers were the culprit. Not having to go inside the transaxle will be welcomed.
Add to jdcart's Reputation
Rate the quality of this post and help jdcart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdcart is offline   Reply With Quote
Old 11-22-2005, 01:56 PM   #4
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
My 97 acts the very same way I will keep an eye on the clutch. I too was suspecting the hydraulics but I guess even after pumping them up it can still be a bear to shift. I did grease up both sides on the shift cable and it did help some however.
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline   Reply With Quote
Old 11-22-2005, 02:29 PM   #5
BarnOwl
BarnOwl's Avatar
Usually it's the hydraulics. If you're low on hydraulic fluid, you know for sure. If you're not, you can try this. With the car stopped and the engine running on a flat surface. Pump the clutch a few times, hold it and put it in gear. Release the brake and continue holding the clutch. If it's hydraulics, the clutch will gradually engage or if it started engaged, it will engage more. If it's the pressure plate, there should be no change as you hold the clutch in.
Add to BarnOwl's Reputation
Old 11-22-2005, 03:37 PM   #6
S3aturnR
S3aturnR's Avatar
1999 SL1
sounds like a gearbox issue to me. low fluid or worn/broken parts will probably be your culprit...
s3aturnr
Add to S3aturnR's Reputation
Old 11-22-2005, 09:15 PM   #7
SKYDude
SKYDude is on a distinguished road
SKYDude's Avatar
My 96 SC2 has the SAME FREAKIN ISSUE! I have been trying to figure it out for a long time. This problem seems to only occur either when the car is cold (first thing in the AM) or when I am stuck in traffic and the car get real hot. I'll push the clutch pedal in (normal feel to the pedal; nothing strange there), the shifter will only go into 1st if I shove it hard (I feel like I am going to break something!) and then once I finally shove it into gear, sometimes it will shudder with the clutch all the way depressed and in gear and just sitting still. If I let the car roll a little, the shuddering stops. It also makes a racket in the tranny when this is happening, almost like the sound the car makes if you are learning to drive stick (that shuddering/shaking feeling). The only way I can fix it is to put it in reverse and then back in first again (usually fixes it for the time being). Any ideas? Should I replace the master/slave assembly? I really don't want to pay for a new clutch now Thanks for the advice
Add to SKYDude's Reputation
Rate the quality of this post and help SKYDude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SKYDude is offline   Reply With Quote
shifter cables jel2211 S-Series Tech 16 04-29-2009 03:49 PM
HELP- shifter cables MikeNW S-Series Tech 13 04-16-2008 11:08 PM
Saturn manual shifter cables sucks! Shifter eyelet came off turbobuick33 S-Series Tech 22 05-28-2007 04:10 PM
Shifter feels loose when its in gear turbobuick33 S-Series General 5 05-17-2006 05:17 PM
Shifter cables edzdallas S-Series General 12 01-18-2006 11:15 AM
