Old 09-14-2011, 09:14 PM   #1
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
Default Well. Shifter Cables.
Any decent aftermarket cable or should i stay OEM, What year cables will work in a 2002 SL2, any variations i can do, Driving to work today, I shifted to second and boom, Shifter went floppy, Pulled over, took off the console. Bushings are okay.. Hmm.. Checked under the hood the U Clip is there... Hmm.... Cable that goes foward and backward is frayed and broken. So, I'm gonna find a decent set of cables from a JY or a dealer, should i go ahead and do the Bushing and endloop?
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
Add to simkid5614's Reputation
Rate the quality of this post and help simkid5614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simkid5614 is offline   Reply With Quote
Old 09-14-2011, 09:21 PM   #2
Default Re: Well. Shifter Cables.
Get a set from the J/Y and just do the bushing. Unless you manage to bind it up the end loop will not fail unless subjected to severe abuse. A set with the oval push in grommet is a definite OEM but those with the rectangular plate may or may not be OEM.
Old 09-14-2011, 09:26 PM   #3
simkid5614
simkid5614's Avatar
I figured to save myself some hassle. Do it all while it's out... Will 96-02 Cables work or 00-02 Only?
Old 09-14-2011, 09:34 PM   #4
Redhotftw!
Redhotftw! will become famous soon enough
any year cables work.
OEM new or junkyard.
aftermarket ones are for the birds.
i dropped over $200 on brand new OEM ones though.
was in a pinch and JY wasnt an option
1998 "Red Hot" Sc2
Add to Redhotftw!'s Reputation
Rate the quality of this post and help Redhotftw! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Redhotftw! is offline   Reply With Quote
Old 09-14-2011, 10:09 PM   #5
simkid5614
simkid5614's Avatar
Okay will doing JY route in the morning before work.. Till then.. Guess i drive th other SL2
Old 09-14-2011, 10:51 PM   #6
If you have to pull them yourself just unbolt the shifter assembly from the floor and take it along with the cables. The 2000+ is the one to grab if you can. How to remove the grommet is in my photo gallery. It is easy once you know how...
Old 09-14-2011, 11:14 PM   #7
simkid5614
simkid5614's Avatar
Most around here. The idiot goes into the yard with you.. He'll end up hacking them up trying to take them out, then they say you have to buy em once they're out.. I'll tell him step by step how to remove em so.. hopefully i dont have to go all the way to Orlando for a U-Pull.
Old 11-09-2011, 12:28 PM   #8
Patman52
Patman52 is on a distinguished road
I myself am on my third OEM cable. They wires keep popping out of the bushing, I guess there is something worn with the tranny or shifter tower.
What I did was just JB weld the crap out of where the cables go into the bushing to keep them from popping out. Pretty easy fix and has lasted over a year as of today.
Add to Patman52's Reputation
Rate the quality of this post and help Patman52 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Patman52 is offline   Reply With Quote
Shifter Cables andyr13 Vue General 5 01-23-2011 10:34 PM
96 SL1 shifter cables doublemm S-Series Tech 20 12-14-2009 12:03 PM
Saturn manual shifter cables sucks! Shifter eyelet came off turbobuick33 S-Series Tech 22 05-28-2007 04:10 PM
Shifter cables edzdallas S-Series General 12 01-18-2006 11:15 AM
Shifter still feels sticky, even after new shifter and cables! 98greenSC2 S-Series Tech 6 11-22-2005 09:15 PM
