Old 12-28-2008, 11:43 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Removing the parking brake cable from the park brake lever
What is the easy way to remove the parking brake cable from the park brake lever?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 12-29-2008, 12:43 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Removing the parking brake cable from the park brake lever
Disconnect the negative battery cable. If equipped, disable the air bag system.
Remove the center console assembly from the vehicle.
Remove the adjuster nut and, if present, the spring from the threaded rod, then disengage the cables from the equalizer assembly.
Using SA9151BR or an equivalent release tool, remove the brake cable from the parking brake base bracket.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-29-2008, 01:50 AM   #3
turbobuick33
1992 SL2
I mean the the cable end on the lever that connects the shoe
92 SL2, 5 speed
91 Lx 5.0
Old 12-29-2008, 06:32 PM   #4
kermit123
kermit123 is on a distinguished road
LOL! That can be hard to do. Push the spring back (compress it) with the lever, then twist the lever to get the little cable nob out of the lever. Pliers help.
Add to kermit123's Reputation
Rate the quality of this post and help kermit123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kermit123 is offline   Reply With Quote
SL2 Parking Brake Lever Q-Tip Fix MINICooperS S-Series Tech 29 08-06-2016 08:37 PM
97 sc2 parking brake cable gaurdien S-Series Tech 7 05-23-2007 08:42 PM
parking brake cable sps SOHC S-Series Tech 1 06-08-2006 04:53 PM
parking brake not working - no tension on lever GmG S-Series Tech 3 09-05-2005 12:41 PM
Parking brake cable Tim T S-Series Tech 6 04-05-2004 09:46 PM
