Old 05-25-2018, 11:30 PM   #1
FloraSL1
FloraSL1 is on a distinguished road
Default SL1 TAAT transmission mystery
Hello everyone,
You may or may not have seen this story on another forum or two. I am admittedly posting on multiple Saturn forums in order to expose this problem to as many minds as possible. I'm desperate for a solution.
I also apologize in advance for the length of this post, but I feel that it is necessary to illustrate exactly where this problem has led me to and why I'm stuck.
The car: 2001 SL1 TAAT automatic transmission 83k miles.
History: I tracked this car down three years ago for my girlfriend to give to her oldest son for his first car. I live in Indianapolis. She lives in Illinois south of Effingham. To put the car even further away, her son is going to college in Carbondale, IL. The car has been brought back to Her house and I have been working on it, but every time I try something else to fix the problem it's a 4 hour round trip. I'm getting tired of guessing.
The original complaint was the car was not wanting to go into third gear, and was bucking/slamming. Reverse was never a problem.
Research pointed to the valve body. Visual inspection showed no burning or indications of the wiring harness failing. The fluid looked good and clean, and smelled normal.
I replaced the valve body, and the attitude of the car changed. It seemed to start off slowly, and it would occasionally slam shift. Again, reverse acted completely normal.
After coming back from the test drive I pulled transmission pan back off and retested the solenoids which all test normal. Post mortem on the old valve body revealed a bad third gear solenoid.
Observation of the car has shown it is starting out in third now. It slowly drags itself up to speed and only shifts once. trying to manually shift it back down into third or second with the gear selector doesn't work. I will not respond.
The next possible solution I was pointed to was a possible loose input shaft nut. That has been tightened to specifications, as well as the output shaft nut. The fluid and filter were changed at the same time for good measure. No change in the car. I can not find any evidence of actual damage or contamination. In addition, every major ground I can locate on the car has been cleaned and tightened.
Further research indicates that in order for first gear to engage, the solenoids for second, third, and fourth must all be energized. Logic is telling me that if the car is starting off in third, that there's a problem with the circuit for the second gear solenoid. Am I crazy or just confused?
The new valve body came with updated Sonnax solenoids. They all check out, however during a subsequent disassembly to try to figure out the continuing failure the solenoids were all moved to different positions. No change in the car's behavior.
The buss plate that connects the wiring harness to the solenoids was also swapped out with the original one, and no change in the car. Both the original and replacement were checked for continuity and passed.
The range selector switch has also been eliminated as a cause. You might be beginning to see the root of my confusion here. All of the usual suspects have been eliminated one by one. I'm out of horses and zebras, and now I'm hunting unicorns.
The car is in a town with very limited options for professional service. There is no specific transmission shop. It was taken to the only mechanic in town which gave it a blanket diagnosis after a test drive of "it needs a new transmission". I disagree due to a complete lack of evidence of damage.
So, first I would really appreciate any other opinions. Secondly, I am looking for specifications for the wiring harness as to what the wires do and what they should read for voltage. I really feel like this is a wiring problem.
Thanks for your time,
Chris
Add to FloraSL1's Reputation
Rate the quality of this post and help FloraSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FloraSL1 is offline   Reply With Quote
Old 05-26-2018, 05:41 AM   #2
Saturn Night
Default Re: SL1 TAAT transmission mystery
You may want to email Ken Partin, from Ken Partin Transmissions, here in Ohio. He can send you the ATSG service manual, which provides extensive trouble shooting instructions.
Looking over the post, you have tested solenoids, replaced the valve body, tightened the input shaft nut.
Going off your post that the car is starting in 3rd gear, and still has reverse shows that the 2nd Gear solenoid is fine.
Reverse and 2nd Gear are on the same solenoid, and the same physical clutch pack within the transmission assembly.
This will bring me to some questions:
Who/Where did you order the valve body from?
There are only three known recommended valve body suppliers, by the forum memebrs here(myself included):
Special Fofces(A Member of these forums)
Ken Partin
Central Valve Body
My next question:
Have you test and check the TRS fuses inside your UHJB(The fuse block near the battery)?
A bad solenoid can cause a short and may have blown a fuse, which will cause issues with no energy going to a good solenoid.
Even with a total electrical failure, the car will retain one forward gear(I think 4th) and reverse so it can be limped to a shop or home.
In the event that a transmission replacement is needed, or you need to source additional parts for this car, there is a helpful website for searching the salvage yards in your area, as well:
www.car-part.com
Saturn Night is online now   Reply With Quote
Old 05-26-2018, 01:02 PM   #3
billr
Where did you get the VB from?
Go back to the beginning and use live-data to avoid most of this guessing. Also, connect a gauge to observe line-pressure.
The next time you have the VB off, do air-checks on the clutches/servo.
Again, where did you get the VB from? There are four different "Sonnax upgrades", and most vendors don't do them all... only do the one(s) they think are important.
Add to billr's Reputation
Old 05-26-2018, 07:36 PM   #4
toggenburg
toggenburg's Avatar
Just for curiosity, what type transmission fluid did you use?
It HAS to be Dexron III compatible, never Dexron IV or anything but DEX III.
Old 05-26-2018, 11:21 PM   #5
ssicarman
ssicarman's Avatar
From the service manual.
Transaxle Shifts
Transaxle shifts are controlled by the manual valve and the PCM through the hydraulic solenoids.
The manual valve controls oil direction to provide 1st gear. When the transaxle has been shifted into D4 or D3, the 1st clutch is applied and the 1st sprag locks the 1st driven gear to the output shaft. The output shaft is driven counterclockwise by the 1st driven gear, causing the differential to turn clockwise in the forward direction. At the same time, 1st oil pressure is directed to the Forward/Reverse servo to assure the dog clutch is moved, locking 2nd driven gear to the output shaft.
At a predetermined point, based on vehicle speed, throttle position, and temperature, an upshift to 2nd will occur when the PCM opens the circuit to shift solenoid 2. When the circuit is opened, the solenoid is turned off electrically and turned on hydraulically, flowing oil to apply the 2nd/Reverse clutch. As the clutch applies, the ratio change causes the 1st gear sprag to overrun or freewheel and the shift to 2nd is complete.
When the transaxle shifts to 3rd, shift solenoid 3 is turned OFF applying oil pressure to the 3rd clutch. Shift solenoid 3 is then turned ON, exhausting the 2nd/Reverse clutch as the 3rd clutch is applied. The 3rd to 4th shift is accomplished in the same manner.
The torque converter clutch (TCC) is applied in 1st, 2nd, 3rd, and 4th gears. The speed at which the TCC will apply in 1st or 2nd is based on vehicle speed and tailored by throttle position, engine temperature, and transaxle temperature. Once applied, the TCC will stay applied until vehicle speed is low enough in 2nd gear for the TCC to release. The TCC will also release when the brake pedal is depressed in 2nd gear at low engine speeds or when the transaxle downshifts into 1st gear.
Reverse is controlled by the manual valve. When reverse is selected, the manual valve directs oil to the Forward/Reverse servo. The servo moves the Forward/Reverse dog clutch to the reverse position, releasing the 2nd driven gear and locking the reverse driven gear to the output shaft. As the dog clutch is engaged, the servo allows oil flow to shift solenoid 2. Shift solenoid 2 is turned OFF allowing the clutch to engage driving the 2nd/Reverse gear. The 2nd/Reverse gear turns the reverse idler gear driving the reverse driven gear clockwise, which in turn, provides reverse.
Have you done any clutch air checks?
Add to ssicarman's Reputation
Old 05-27-2018, 12:21 PM   #6
FloraSL1
The valve body came from Genuine OEM recyclers off of Ebay. They are based in Buffalo, NY.
In answer to another question, yes I was careful to use Dexron III.
Old 05-28-2018, 05:16 PM   #7
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
If it is starting off in 3rd, that would suggest the 3rd Gear Solenoid is not getting energized. You didn't mention anything about the 3 TRS Fuses.
Add to Chazberry's Reputation
Old 05-28-2018, 05:59 PM   #8
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
Here is the schematic for the VB. The engine must be running for the Fuel Pump Relay to be energized so that B+ is sent to Pin A on the VB Harness (3rd Gear Solenoid power) . . .
http://www.saturnfans.com/forums/att...8&d=1355417038
Old 05-28-2018, 07:16 PM   #9
FloraSL1
The fuses check out. Thinking about what you said about the third gear solenoid not energizing makes sense. This will be my next thing to investigate when I get my hands on it. I never was a transmission guy. Thanks for the direction. I will post an update once it's available.
Chris
Old 05-28-2018, 10:03 PM   #10
Saturn Night
Chris
Check the BUS plate for a bent pin, or damaged wiring.
Old 05-29-2018, 10:30 AM   #11
bowlby29
bowlby29 is on a distinguished road
2000 SL2
+1 for wiring issue -- I had a similar issue years ago after a rodent chewed through my transmission wiring harness. Car started in 3rd, had a hell of a time getting going and slammed occasionally, but drove fine once it was up to speed. Reverse worked as well. New wiring harness (~$400 installed at dealer) resolved issue entirely.
2000 SL2 200k miles
Add to bowlby29's Reputation
Rate the quality of this post and help bowlby29 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bowlby29 is offline   Reply With Quote
Old 08-05-2018, 10:26 PM   #12
FloraSL1
Bumping thread with update. I now have the car in my possession so it's easier for me to work on it and try ideas.
I located a bad wire running to the #3 solenoid. It was bad at the plug for the pan. I wired in the new harness VERY carefully. I am not new to wiring. Now things have instantly changed.
The car made it all the way from Carbondale, Illinois with just 3rd, 4th, and reverse working. Reverse did not slam. After installing the new harness I have 2nd, 3dr, 4th. !st is still not working, and now it slams into reverse so hard the vehicle stalls.
I am despondent. I need someone smarter than I am to lead me here.
Old 08-06-2018, 03:33 PM   #13
Saturn Night
Reverse and Second gear are on the same solenoid, same clutch, and same fuse.
Slamming into reverse is usually a Line Pressure Solenoid issue.
Did you try contacting Ken Partin, of Ken Partin Transmissions?
Loss of first would like be something with checking additional wiring and the 1st Gear solenoid.
Old 08-06-2018, 08:10 PM   #14
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
There was a color code change in '96. Any chance that messed you up?
Old 08-06-2018, 08:33 PM   #15
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
PS - there is NO 1st Gear Solenoid. The 1st Gear Clutch is engaged mechanically in all gears.
Old 08-08-2018, 01:47 PM   #16
Saturn Night
Crap, that's right. there are only 5 solenoids. Sorry about that. LP, TCC, 2nd-4th.
Good thing you corrected me on that one.
Old 08-12-2018, 12:09 PM   #17
FloraSL1
Well, I only used the color codes on the original wiring harness as as secondary check on what was being spliced in at the moment. I changed each wire based on location, one at a time, with a carefully marked new harness. The colors and locations on the car itself matched the above chart. I really thought I had it this time, especially after finding a bad wire at the plug in the original harness.
I am suspicious that I still have a bad connection in one of the MLP wires, specifically the dark blue wire.
I will be going out to try to verify that this afternoon.
Old 08-12-2018, 03:07 PM   #18
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
1995 SL2
Once the wiring is sorted, try a valve body that has the Sonnax sleeve in it. I wonder if the ones you have are worn?
I had great results from that. Reverse slam was crazy hard, and forward slams were bad too. Never lost a gear completely though. Sonnax sleeve VB fixed it
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-12-2018, 04:34 PM   #19
FloraSL1
I'm still stalling going out to look at this. To be honest, this is the most trouble I've ever had trying to fix a car issue. I have begun to actually hate this car and I am considering buying it from my girlfriend and donating it to the local fire department so they can set it on fire and practice putting a car out.
With that said, in response to the last post, this change was immediate after wiring in the new harness. It had reverse up until then, with zero slam issues.
I did check the actuator rod and piston the last time I had it apart to make sure it didn't come unhooked. It seems to be installed correctly. It's not possible to install that piston upside down is it?
Chris
Old 08-12-2018, 06:24 PM   #20
FloraSL1
Alright... I studied the above wiring schematic. I can confirm I have continuity of the dark blue wire all the way from the PCM connector to the transmission.
However, I can not seem to get any sort of continuity reading between the red wire that's also involved with the line pressure solenoid and either of the fuse ports in the fuse block. I will have to go get more connectors and continue the investigation.
Thanks to everyone for their input so far.
Chris
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 09:28 AM
TAAT Transmission Valve Body Nickbo L-Series Tech 1 06-03-2013 05:36 PM
Taat Transmission problem re hum funnyfarm S-Series Tech 9 09-04-2009 08:36 AM
TAAT transmission (or not) k1rod S-Series Tech 4 10-23-2008 01:14 PM
TAAT transmission eXmortal S-Series Tech 18 05-15-2008 09:57 AM
