Old 04-24-2010, 10:47 PM   #1
dbaier
dbaier is on a distinguished road
Default Bad front wheel bearing?
I have 1996 SL2 with 180,000 miles on it. I'm noticing a high pitch whine at 55 and above, I thin it may be bearing related. It does not make the sound when revving and holding at 2000 rpm parked. Any thoughts? Thanks.
-Dave
Current DD
1999 SC1 100,000
Kids car
1996 SL2 222,000
SOLD to a nice family that needed a car.
1999 SL 184,000
RIP
Add to dbaier's Reputation
Rate the quality of this post and help dbaier reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbaier is offline   Reply With Quote
Old 04-25-2010, 09:44 AM   #2
bluesl2
bluesl2's Avatar
Default Re: Bad front wheel bearing?
Does the noise change if you steer a little to the left or right when driving? If it does it's probably a wheel bearing.
Add to bluesl2's Reputation
Old 04-30-2010, 06:08 PM   #3
dbaier
No change in sound when turning wheel. The sound is like a whirling sound it gets louder the faster I go.
-Dave
Current DD
1999 SC1 100,000
Kids car
1996 SL2 222,000
1999 SL 184,000
RIP
Old 05-01-2010, 03:01 PM   #4
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Check for a bad tire or bad bearing
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 05-01-2010, 04:56 PM   #5
valleyforge
valleyforge is on a distinguished road
I have 95,SL2 . I had a bad bearing. I had Sears press it out and replace for $100.
Add to valleyforge's Reputation
Rate the quality of this post and help valleyforge reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
valleyforge is offline   Reply With Quote
Old 05-01-2010, 06:40 PM   #6
dbaier
I just rotated the tires. Sound is still there. I jacked up the car after my test drive to wiggle the tire. Should there be any play? I am getting some side to side play.
-Dave
Current DD
1999 SC1 100,000
Kids car
1996 SL2 222,000
1999 SL 184,000
RIP
Old 05-02-2010, 05:58 AM   #7
vtsl2
vtsl2 is on a distinguished road
vtsl2's Avatar
There should be no play, but you want to check it at the 6 and 12, 3 and 9 will tell you if your tie rod ends are bad.
If it is just starting to go you may not have any play yet.
SATURNS ROCK: THATS ALL I HAVE TO SAY
99 sc2m mine
94 sl2m my sons
10 ford Taurus with paddle shift(cool)
99 sw2a converted to manuel
02 chevy Silverado extened cab stepside
99 sl2m retired
Add to vtsl2's Reputation
Rate the quality of this post and help vtsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vtsl2 is offline   Reply With Quote
Old 05-03-2010, 09:59 PM   #8
dbaier
Looks like I need to replace a bearing. Any one done this lately? Autozone has the bearing for $30. Do I need the slide hammer? Should I try to find one at a junk yard? How hard is this job? Thanks. Sorry for the rambling....
-Dave
Current DD
1999 SC1 100,000
Kids car
1996 SL2 222,000
1999 SL 184,000
RIP
Old 05-03-2010, 11:15 PM   #9
gizzi
gizzi is on a distinguished road
gizzi's Avatar
2000 SL2
2002 SL1
Its not a very difficult job...there are a few ways in which you can replace the bearing. Take the knuckle/strut assembly off the car and then bring it to a shop for them to press the bearing out and put the new one in.
The way I did mine was with the Harbor Freight front wheel bearing kit. http://www.harborfreight.com/fwd-fro...ers-66829.html
I took the knuckle off the car to make for easier access to the snap ring, even though with the kit you can leave the knuckle on the car. The snap ring will likely need a lot of persuasion to get loose and out. In my case I wasn't concerned with alignment because I was replacing the struts anyway. The kit works really well for removal and installation but I would recommend having pneumatic tools to make life easier.
Add to gizzi's Reputation
Rate the quality of this post and help gizzi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gizzi is offline   Reply With Quote
Old 05-04-2010, 05:46 PM   #10
dbaier
I can get just the bearing for about $45 and a local parts place will press it in for $39. Need to have in by 10:00 am to get it back the same day. Any tricks or tips? Do I need the tie rod end puller? I wish Richpin had a video on this. The only one I could find was super fast and hard to follow. Thank you.
-Dave
Current DD
1999 SC1 100,000
Kids car
1996 SL2 222,000
1999 SL 184,000
RIP
Old 05-04-2010, 11:36 PM   #11
gizzi
gizzi's Avatar
2000 SL2
2002 SL1
[QUOTE=dbaier;1618028]I can get just the bearing for about $45 and a local parts place will press it in for $39. Need to have in by 10:00 am to get it back the same day. Any tricks or tips? Do I need the tie rod end puller? I wish Richpin had a video on this. The only one I could find was super fast and hard to follow. Thank you.[/QUOTE
To remove the strut/knuckle assembly is just the three nuts on the strut mount (in engine bay, by strut tower) and then the tie rod, lower control arm and axle nuts. Be prepared to pop out both ball joints from the knuckle. You'll also have to move the caliper off of the rotor and set both aside. Just do a search, plenty of info on this site.
Old 05-05-2010, 05:30 PM   #12
dbaier
gizzy, are you available Saturday in Sussex to assist? Or any one else in the western side of Milwaukee. I don't know my suspension terminology well but I have not seen the knuckle/strut assembly how-to version. So I can take that assembly in and they will be able to press the bearing? Thanks.
-Dave
Current DD
1999 SC1 100,000
Kids car
1996 SL2 222,000
1999 SL 184,000
RIP
Old 05-05-2010, 05:34 PM   #13
S3aturnR
S3aturnR's Avatar
1999 SL1
your play is likely a bad bushing in the lower control arm. your whirring sound is quite possibly the bearing, especially if it's still there after a tire rotation. i hate to see you blindly throw parts at it, but all those parts are probably due for replacement anyway...
s3aturnr
Add to S3aturnR's Reputation
Old 05-06-2010, 03:13 AM   #14
gizzi
gizzi's Avatar
2000 SL2
2002 SL1
PM sent
front wheel bearing Thundercat Vue Tech 13 01-07-2010 12:09 PM
Front Wheel Bearing: DIY or not? BryanF Vue General 2 04-10-2009 05:26 PM
Front wheel bearing... ym42 S-Series Tech 17 04-16-2006 09:55 AM
ABS front hub / wheel bearing IMkenNY Vue Tech 0 03-22-2006 12:14 PM
Front Wheel Bearing mike Miscellaneous Tech 18 10-24-2004 11:42 PM
