Old 05-13-2014, 09:24 AM   #1
goatcheeser
goatcheeser is on a distinguished road
1994 SL1
Default Help Needed
Greetings,
I own a 1994 Sl1 with a little over 75000 miles on it. Lately, I have been having problems with the car overheating when idling, and/or when I am stuck in stop and go traffic. I had someone tell me to replace the thermostat and am doing that today. However, the overheating is not my main concern. This is where it gets weird and I hope you are able to follow my explanation of the problem. Whenever the car would overhead, my check engine light would come on and the car would not shift out of first gear; it would just rev to about 4000+ revolutions per minute and then sputter when I took my foot off the accelerator. I have never had a problem fixing this. All I have to do is turn the car off and restart it. Not only does restarting the car remove the check engine light, but it also seems to fix the shifting problem. I thought the problem was directly related to the overheating, and it might be; however, someone suggested I could keep the temp. down by running the ac; this helped with the temp., but I still had the same check engine light and problem shifting after being stuck in traffic again. I did recently have a a leak in a spark-plug well. I changed the plug and the gasket but did not change the spark plug wire, also being fixed today. I recently had to change the top engine mount, but it took me a while to diagnose the problem so the engine was regularly shaken for a spell. Thank you in advance for your help.
-Goat
Add to goatcheeser's Reputation
Rate the quality of this post and help goatcheeser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goatcheeser is offline   Reply With Quote
Old 05-13-2014, 10:10 AM   #2
MadPuppy
MadPuppy is on a distinguished road
MadPuppy's Avatar
Default Re: Help Needed
I think the coolant temp sensor helps control shifting in automatics, it may be that the overheat tripped the sensor and the sensor would not let the PCM get the trans out of 1st gear. I would consider fixing the overheat condition and/or replacing the coolant temp sensor.
National Debt is a loan, with nothing of serious value given by the lender in exchange for your time and labor, it's a loan we can't pay off, and the financial system as it is would end if we did.
Add to MadPuppy's Reputation
Rate the quality of this post and help MadPuppy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MadPuppy is offline   Reply With Quote
Old 05-13-2014, 10:34 AM   #3
el diablo viejo
el diablo viejo will become famous soon enough
el diablo viejo's Avatar
1994 SW1
2000 SW2
You have two sensors, one for the gauge with a single wire connector, and one for the pcm with a two wire connector, which is the one you want to change. They are both on the the driver's side of the head, just take off the intake air tube to gain access. This is always a good place start. You should also read any stored OBD1 codes and post them here.
Have you read this http://www.saturnfans.com/forums/sho...d.php?t=177672 ?
97 sl2 a/t 104 K
1989 GMC 3500 454 129 K, 1969 442 455 rat rod
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
el diablo viejo is offline   Reply With Quote
Old 05-13-2014, 12:25 PM   #4
Replace the original two-wire coolant sensor. This sensor indirectly causes xmission shift issues when the engine computer is given incorrect coolant temperature signals. Replacing the faulty sensor will correct the overheating problem.
Old 05-14-2014, 11:21 AM   #5
goatcheeser
1994 SL1
UPDATE:
I want to start by thanking you all for your help. I decided to put off replacing the thermostat. Many of you have suggested changing the cooling sensor. Replacing the sensor seems like an easier fix than draining my coolant system to replace the thermostat. Yesterday, I was given the wrong sensor and am now waiting for my car to cool down before attempting to replace the old sensor with the correct part. I am a bit concerned because I did remove the old sensor to see if there was any noticeable damage, there wasn't. This is slowly becoming a cluster and am starting to fear that I may just have to bite the bullet and take it to a professional. I will be sure to update once the new sensor is in. Thanks again.
-Goat
Old 05-14-2014, 11:59 AM   #6
Was the tip on the sensor you pulled out flat, or rounded?
When you turn the AC on, the engine fan should come on full speed. Does it do that?
Old 05-14-2014, 12:08 PM   #7
goatcheeser
1994 SL1
It is rounded and yes, when I turn the ac on the fan does come on.
Old 05-14-2014, 03:32 PM   #8
screwpid
screwpid is on a distinguished road
1993 SL2
Sounds like you need to upgrade that sensor to the copper one thats flat. That sounds like the oem temp sensor. You should have changed that last year! Paperclip your car and post the code you are getting.
Add to screwpid's Reputation
Rate the quality of this post and help screwpid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
screwpid is offline   Reply With Quote
Old 05-14-2014, 04:14 PM   #9
Sc86gt
Sc86gt is on a distinguished road
Add to Sc86gt's Reputation
Rate the quality of this post and help Sc86gt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sc86gt is offline   Reply With Quote
Help needed! AstraLover Astra General 10 12-17-2012 11:08 PM
Help Needed SL2confusion S-Series Tech 2 04-10-2011 04:45 PM
little help needed new S owner S-Series Tech 6 01-20-2008 12:44 AM
A/C help needed tfbthg S-Series Tech 42 07-28-2007 11:19 AM
95 - SOHC Heads needed...or help needed hamill S-Series Tech 15 10-31-2005 10:48 PM
