Old 03-15-2005, 04:43 PM   #1
sat95sl1
sat95sl1 is on a distinguished road
Question Timing chain replacement - when?
I have 150,000 miles on my 95 sl1. At what point should the timing chain be replaced. Should I do this soon? Or wait a little while longer? At how many miles should a timing chain be replaced?
Thanks.
sat95sl1 is offline
Old 03-15-2005, 06:50 PM   #2
dieseljack
dieseljack is on a distinguished road
Default Re: Timing chain replacement - when?
With regular oil changes, the chain should last indefinitely. The one on my '95 SW1 is original at 357,000.
dieseljack is offline
Old 03-16-2005, 04:40 PM   #3
sat95sl1
Thanks for your reply.
So there isn't any precautionary time to replace it before it snaps on the highway going 70mph?
Thanks again.
sat95sl1 is offline
Old 03-16-2005, 04:48 PM   #4
SL2Dreams
SL2Dreams is on a distinguished road
SL2Dreams's Avatar
2004 ION-2 Sedan
1995 SW2
technically you could check by removing the timing chain cover and measuring how far out the chain tensioner comes out. I believe the service limit is 1/2" This is no easy feat though
SL2Dreams is offline
Old 03-16-2005, 04:49 PM   #5
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Thanks again.
It's a chain - not a belt. If the car gets regular oil changes, the chain should theoretically outlast the engine.
Contrasting this, belts last for usually about 100,000 miles (recommended change interval anywyas... cheaper to get it done then to make pistons meet valves...)..
Kevin
Kevin94SL is offline
Old 03-16-2005, 05:20 PM   #6
RedLimeVued
RedLimeVued is on a distinguished road
2004 VUE Red Line
Replacement of the chain due to elongation (wear of the pins and the chain link apertures) is dependent on a lot of factors, of which milage is one of them. All timing systems have a resonance point where chain tensile loads are much higher and typically pretty dynamic. If the car is driven at an RPM where system resonance is occuring, then you may see the chain wear faster. The main component of chain wear is soot in the oil. The soot is abrasive and actually increases wear of the pins and link apertures, and as these wear, the chain elongates (pins become smaller diameter and apertures become larger diameter or oblong). So, per the post below, having clean oil will prolong the life of the chain for sure. Also, consider runtime on the engine. We see alot of "early" timing system failures in terms of milage (under 20K miles) but the application is a police car or a taxi cab. The vehicles only show 20K miles but the were running 24/7 for a couple years sitting in traffic, running radar, etc.
It never hurts to replace the chain, but 150K miles is a better interval since that is the design requirements for most engines. The 8mm roller chain in the Saturns should last quite a while, they wear less than silent (inverted tooth) type timing chains. Also, per the post below, if you remove the timing cover take a look at the tensioner. If it is almost out of stroke then it's a good idea to replace the timing chain. Most tensioners are designed to take up 0.7% worn chain.
I have a picture of the DOHC timing system in my members gallery.
RedLimeVued is offline
Old 03-16-2005, 07:22 PM   #7
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
When they make noise.
I have yet to hear of one breaking...
BlackBirdRacing is offline
Old 03-16-2005, 07:31 PM   #8
geckobuddy
geckobuddy is on a distinguished road
1994 SL1
I read in my saturns' manual to check the chain at 100k and certainly when it starts to make noise (you'll know the noise when you hear it)
Personally, My 1994 just flipped 100k and I'm taking it in tomorrow to get a new chain. Of course, mine is a bit noisy so I'd rather spend a few-hundred now then worry about an engine re-build later.
BTW - well put explanation by REDLIMEVUED -
geckobuddy
geckobuddy is offline
Old 03-16-2005, 10:47 PM   #9
Low Saturn
Low Saturn's Avatar
2007 AURA XR
I generally change them myself at around 100,000 miles. I pick up a LOT of used Saturns and don't know how well they're maintained. So a $140 timimg chain kit is cheap insurance.
Low Saturn is offline
Old 03-17-2005, 11:59 AM   #10
geartooth94
geartooth94's Avatar
I'd say 175K at the most for a timing chain change interval.
The '95 SOHC engine I rebuilt had its tensioner extended to the max at 196K miles.
geartooth94 is offline
Old 03-17-2005, 02:24 PM   #11
blimey
blimey is on a distinguished road
Would the noise from a worn timing chain be constant or ocassional? My '95 SL1 has a little bit of clacking noise only when under load up a hill. 128k on orig chain.
blimey is offline
Old 03-17-2005, 03:54 PM   #12
Razorbak
Razorbak's Avatar
Noise from a worn timing chain set is very noticeable at idle speed.
Razorbak is offline
Old 04-12-2005, 11:59 AM   #13
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I also have a rather loud engine while idling. I'm guessing it's the timing chain. Is there a way to check the stretch of the chain or definite numbers when you measure it? On a bike, if you place a ruler along the chain and line up one rivet on the 0" mark then the corresponding rivet should line up with the 12" mark. Depending on how much it falls before the 12" mark will dictate when you should replace your chain.
I'm without my manual right now, is there a similar way to measure this with the valve cover removed?
--Tom
Not a Saturn.
Tom92SCm is offline
Old 04-12-2005, 12:28 PM   #14
Low Saturn
Low Saturn's Avatar
2007 AURA XR
--Tom
Yes. Remove the cam cover and spark plugs, then using a socket and breaker bar, turn the crank. You'll want the two silver links at the crank gears 6:00 position (you wont be able to see this) and one silver link at each of the cam gears 12:00 positions. The center of these links should line up with litte divits on the cam gear. If one of the link lines up and the other is a little off, the chain has stretched.
Old 04-12-2005, 12:37 PM   #15
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
AWESOME reply! That's the first time I've ever seen a definitive way of telling if the timing chain needs to be replaced or not. I've got a leaky valve cover gasket so the cover is going to be coming off soon anyway. Now I'll know if I'll need to set a weekend aside to replace the chain.
THANKS!
--Tom
Not a Saturn.
Tom92SCm is offline
Old 04-12-2005, 05:30 PM   #16
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Also if I remember correctly while the links on the cahin are in the correct positions, the word "UP" should be right side up on the right side of the gear with the bottom of the letters alligned with the top of the front cover.
Old 04-12-2005, 05:46 PM   #17
Razorbak
Razorbak's Avatar
The center of the links will always line up with the pip marks on the cam sprockets, even if the chain has stretched, unless the chain was not aligned properly when installed or it has physically skipped a tooth. However, if the chain has stretched, one of the pip marks will not be at the 12:00 position. Some stretch is inevitable unless the chain is brand new, which is why the timing chain set design incorporated a ratcheting chain tensioner in the first place. There is a specified service limit in the FSM for the length of an outstretched chain laying flat with both sides touching. If you know the number of links in the chain, I suppose you can calculate the equivalent service limit measurement between the two pip marks.
Razorbak is offline
timing chain replacement? Mike88 L-Series General 9 08-16-2007 09:54 PM
Timing Chain Replacement DonP S-Series Tech 5 07-06-2007 12:09 PM
Timing Chain replacement trimjb S-Series Tech 3 03-26-2007 04:40 PM
timing chain replacement mkosem Miscellaneous Tech 1 10-13-2003 04:25 PM
timing chain replacement SIYAM S-Series Tech 2 02-10-2001 11:17 AM
