Old 04-21-2015, 08:00 AM   #1
fixityourselfer
fixityourselfer has a spectacular aura aboutfixityourselfer has a spectacular aura aboutfixityourselfer has a spectacular aura about
Default engine from '92-'93 compatible with '95 car?
my car is a 1995 SL MT DOHC. fried the engine a while back when it ran out of coolant.
I have a DOHC motor available that was taken from either a '92 or a '93 SC .
Will it be a direct fit to my car?
fixityourselfer is offline   Reply With Quote
Old 04-21-2015, 08:27 AM   #2
Default Re: engine from '92-'93 compatible with '95 car?
The heads are different and generally incompatible.
Old 04-21-2015, 09:47 AM   #3
2NDSOUT
2NDSOUT's Avatar
1999 SL
As a general rule:
91 model year is a beast within itself as it did not have many things that were present on later model year cars.
92-94 are basically compatible with each other.
95 is getting into Gen 1.5/Gen 2 territory, so some engines and car interiors are a mish-mash of first and second gen part fittings (think of the EGR Valve, and in some cases the Cam Cover as some were Aluminum and I think in 95 some engines started seeing the Composite Covers until the full switch over in 95-96 model year).
To the OP- are you looking to swap an engine or ? If so, just find one that is reasonably priced/mileaged for your model year 95 car and the same transmission (Auto or Manual) and just drop it in.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 04-21-2015, 09:56 AM   #4
'91-'92 you'll have to swap the crankshaft to a '93+ to put the block in a '93+.
If it's a '93 then other than the EGR it's good to go. Even the EGR is "fixable".
Check the VIN stamped on the bell housing flange, right where the coil packs would cover up. Should be the last 8 digits of the VIN of the car it came from use this page to figure out the year: http://www.differentracing.com/tech_...in_decode.html
Old 04-21-2015, 03:35 PM   #5
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
EGR won't work with a '95 PCM.
Swap the PCM out of the car you got the motor from and it'll drop right in.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Old 04-21-2015, 03:53 PM   #6
billr
You can install the electric EGR on the old engine, leave the PCM alone; especially if you have emissions inspections.
Old 04-21-2015, 04:32 PM   #7
fixityourselfer
I only have the engine, I dont have the bell housing flange.
Is the VIN stamped into the engine anywhere?
Old 04-21-2015, 05:00 PM   #8
fixityourselfer
Also, is it possible to tell if its the 91-92 crank or the 93-95 crank by looking at it?
Old 04-21-2015, 05:56 PM   #9
The number is located on the ENGINE bell housing flange.
http://imgur.com/FSRTP
http://imgur.com/V96OM
http://imgur.com/V96OM 1 set is on the engine and the other is on the transmission.
Old 04-21-2015, 06:01 PM   #10
Only by direct comparison.
http://www.saturnwiki.com/wiki/index...tle=Swap_Guide
Old 04-22-2015, 08:01 AM   #11
fixityourselfer
all I could find on the block are 21000950 in the center of the block .
is this what I am looking for?
Old 04-22-2015, 08:31 AM   #12
2NDSOUT
2NDSOUT's Avatar
1999 SL
No...
Refer to OldNuc's Photos.
You may have to really clean your engine up near the bottom.. there is alot of grime and dirt that collect just south of where the Coil Packs are located in order to see the numbers stamped into the block and bell housing.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 04-22-2015, 09:15 AM   #13
fixityourselfer
got it- some cleaner and a toothbrush did it.
8PZ264724 is whats stamped on the flange.
Does this mean its a 1993 motor?
Old 04-22-2015, 09:22 AM   #14
fixityourselfer
if this is a 1993 can I assume the block crank and pistons etc are identical to the 1995? I'll use a 1995 head if need be.
Old 04-22-2015, 09:24 AM   #15
P=1993
Only issue will be making the EGR work, if you can "fake" a drill press in your garage that isn't really an issue either.
Changing engine and BCM, compatible years? netshadow S-Series Tech 3 11-13-2010 06:07 PM
Engine for 99 SL2 Compatible with 95 SL2 ddechene S-Series General 3 12-12-2008 09:52 PM
1997 SL2 need DOHC engine, what years are compatible? J302 S-Series General 1 12-02-2005 01:09 AM
WTB: Compatible Engine/ Transmission DOHC 97 Sc1 KBS_Caveman Classifieds 1 10-16-2005 11:28 PM
Engine Swap-ability Which years are compatible? Fricken eh! S-Series Tech 10 08-25-2004 12:27 PM
