Old 03-12-2014, 04:51 PM   #1
Welderdude
Welderdude is on a distinguished road
Default new ecm relearn
I'm putting in a new ecm in 2003 L300 after replacing the throttle body and tac. The seller stated I have complete the engine/theft relearn steps. Is that something that can be explained here?
Thanks
Welderdude is offline   Reply With Quote
Old 03-12-2014, 05:25 PM   #2
Default Re: new ecm relearn
Here's a brief reprint from the service manual;
30 Minute Learn Procedure
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON, vehicle will not start.
  3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds.
  5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes, the vehicle is now ready to relearn the Passlockô sensor data code and/or passwords on the next ignition switch transition from OFF to CRANK.
    Important
    The vehicle learns the Passlockô sensor data code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  6. Start the engine, the vehicle has now learned the Passlockô sensor data code and/or password.
  7. With a scan tool, clear any DTCs if needed, history DTCs will self clear after 100 ignition cycles.
Old 03-13-2014, 12:51 AM   #3
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
I thought it had to be reprogrammed like the BCM? And required a Tech II from GM dealer service shop to get the right programming?
Old 03-13-2014, 10:15 AM   #4
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Negative, there is no proprietary information in the ECM tied to a specific VIN like there is in the BCM. Additionally though, the "fuzzy logic" settings will be gone, so it may take several weeks for the new ECM to figure out the particular driving habits of the new "owner" and the car may have a different feel while the fuzzy logic learns the new habits.
Jerry N
Groucho Marx
Old 03-22-2014, 12:45 PM   #5
Welderdude
Thanks for the info it finnaly works I changed throttle body, tps, and then ecm. it now runs again.
3.0 tps relearn vanish72 Vue General 2 01-21-2014 11:43 PM
crank relearn ddeuces22 S-Series Tech 16 11-15-2013 01:01 AM
ECM relearn help please fast5thgen Vue Tech 5 11-20-2010 10:08 AM
CPS relearn procedure harley2003 S-Series Tech 12 03-16-2009 10:33 PM
Passlock relearn... (optional relearn) austin71184 S-Series Tech 2 05-31-2006 05:51 AM
