Old 12-12-2008, 07:19 PM   #1
ddechene
ddechene is on a distinguished road
1998 SW2
Default Engine for 99 SL2 Compatible with 95 SL2
Hey all,
I'm pretty sure these are the same motor, but wanted to confirm. If anyone can confirm that fact for me it would be great (I don't have the '99 locally available to confirm). Also does it require an ECU swap or is it a straight drop?
--Dan
ddechene is offline   Reply With Quote
Old 12-12-2008, 08:09 PM   #2
wishihadacamaro
wishihadacamaro is on a distinguished road
Default Re: Engine for 99 SL2 Compatible with 95 SL2
I think the 95 was OBDI, but that's about as much advice as I can give you. Wait for some smart people to find this thread.
wishihadacamaro is offline   Reply With Quote
Old 12-12-2008, 09:34 PM   #3
rc1488
rc1488's Avatar
Car - 95 DOHC
Donor - '99 DOHC
Engine will fit.
Use the '99 manifolds (intake/exhaust)
Use the '95 fuel rail and injectors
The '99 manifold has the air pump stuff on it. Install it but it wont do anything. it just sits pretty above the a/c
Use the '95 flexplate/flywheel
Use the '99 throttle body
Use the '95 IAC and TPS
Plug and play after that
Old 12-12-2008, 09:52 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Drill and tap a provision for the second temperature sensor. 99 has one, 95 has two. Some sensors are different too. Swap the ones from the 95 engine onto the 99 engine.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
1999 sl2 with 1997 sl2 engine need help xtchc1978 S-Series Tech 10 05-08-2009 03:11 AM
97 SL2 engine and tranny fit in a 99 SL2? dnmoreno S-Series General 4 12-19-2006 01:15 AM
1997 SL2 need DOHC engine, what years are compatible? J302 S-Series General 1 12-02-2005 01:09 AM
'02 SC2 Alternator compatible with '97 SL2? SL2Maniac S-Series Tech 2 09-12-2004 07:54 PM
are 5sp and automatic hubs compatible??? 94 SL2 Fricken eh! S-Series Tech 2 08-20-2004 12:33 PM
