Old 08-01-2020, 09:02 AM   #1
454cid
Default P0420 popping up after highway runs sometimes
I've had the P0420 Cat inefficiency code pop up a couple of times now over the course of maybe a month or so. I've read that it's either a dead cat, or a leak in the exhaust. I simply reset it with the scanner.
I think I may have gotten it last fall a time or two as well, but I don't recall for sure. Late last year my mileage dropped off.... maybe when we switched to winter gas, but it was more than I thought it would be.... like 5, 6, or 7 mpg down on the highway. It's back up to the low 30s now....I've hit 34 once. Sometimes I feel like the car isn't accelerating hard enough, and that I'm dragging an anchor, but maybe that's me being in a hurry and expecting too much from a 1.9L 100+ hp engine.
Here's the thing, I was reading that when reset, the code would be back in 150 miles when a test was re-run. I drive that in a day and a half, and I'm only seeing the code after a few weeks...usually after a highway run.
Any ideas? I'm not going to spend money on this. I'm hopping to retire the car this fall. I'm mostly just curious.
1999 Chevy K3500
Old 08-01-2020, 10:26 AM   #2
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Default Re: P0420 popping up after highway runs sometimes
Mine does the exact same thing. Everything is good then infrequently, upon deceleration after a long highway trip, I'll pop a 420. I clear it with my scangauge and I'm good again. Mine only pop about once or twice a year though. I might try the laquer thinner trick for potential cat cleaning, but other than that, not going to worry as I'm only hoping to get a couple more winters out of her. Would be curious though if it was a simple cheap fix, I might try it
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 08-01-2020, 11:52 AM   #3
Are either of you using live-data to check things? There are many things that could cause an intermittent P0420; too many for guessing or parts-swapping, in my opinion.
Old 08-01-2020, 11:55 AM   #4
454cid
I wouldn't know what to look for, and since I'm driving I may not have the time to fiddle with the scanner. Time before last, was as I was just getting to work, for instance. My scanner, might store a snap shot of data as the code is set. I could check for that next time.
1999 Chevy K3500
Old 08-01-2020, 02:11 PM   #5
I understand the difficulty in trying to drive while you watch data; you need to have somebody else drive. Of course, this can be impractical with an intermittent. Look into an ELM327 device and SW that does data-logging.
Honestly, though even with logging it can be a tedious and confusing chore. Hopefully, with just brief looking at live-data you can quickly narrow the search; see flaky readings for sensors like MAP, TP, ECT, IAT, O2, EGR, etc.
Since you are planning on an extreme "parts swap" (replacing car) anyway, just ignoring this code may be most practical for you.
Old 08-01-2020, 02:34 PM   #6
454cid
... just ignoring this code may be most practical for you.
That's the plan unless I find out it's some easily fixed thing. The car is getting too rusty underneath for my liking to put money into it.
1999 Chevy K3500
Old 08-01-2020, 03:34 PM   #7
Macgyver
Get one of these. It pulls the o2 sensor out of the exhaust stream and will turn off the light. You don't have to disconnect the o2 sensor, just thread this in between the pipe and sensor.
https://www.ebay.com/itm/J-Style-O2-...X/113928501357
Old 08-03-2020, 09:34 AM   #8
Ricketts
2000 SC1
Been thinking of that, if mine starts doing it more often I'll look into it
Old 08-12-2020, 08:21 AM   #9
waiter21
2003 VUE 2.2L
I used regular ole spark plug defoulers on my Vue. They run about $7 for two of them.
https://www.amazon.com/Dorman-42009-.../dp/B000CO91FY
I used both of them on the O2 sensor. On one of them, the hole needs to get drilled out so it can screw all the way onto the sensor. Then this screws into the second defouler. You can see this in the photos I took. This was like 4 years ago, never seen a 420 since.
Heres the link on how I did mine:
http://www.saturnfans.com/forums/sho...d.php?t=219738
Old 08-12-2020, 09:13 AM   #10
454cid
Thank you. If I pursue a fix, this will likely be it. Right now, I'm messing with my blower motor..... just ordered one. For now I have zip ties putting pressure on the connector that seems to be faulty.
So far the P0420 hasn't come back again.
1999 Chevy K3500
93 sl2 runs fine but then runs like crap Skubasteve97 S-Series Tech 1 12-12-2015 11:57 AM
Getting P0420 alemeno214 S-Series Tech 2 02-18-2015 04:43 PM
2006 ION runs, then stalls, restarts and runs again with no SES indication DoctorKnow Ion Tech 21 05-23-2013 07:09 PM
P0420 Need Help! Dgatorfan Ion Tech 5 11-30-2011 06:57 AM
93 Saturn SL 5SPD, Runs stalls... runs Chanman S-Series Tech 1 01-05-2009 06:45 PM
