Old 08-06-2020, 03:14 PM   #21
floridasl22002
Default Re: the old mode actuator trick in the hvac
Just googled "GM actuator gear wheels". Look what I got....
https://www.ebay.com/i/162615207560?...BoCVlcQAvD_BwE
Old 08-06-2020, 07:54 PM   #22
rfisher, if you can remove the actuator for bench assessment, you might be able to disassemble it to reveal the inner workings and if they're repairable. At the least, I'm curious and I think I have one actuator on its last legs, the recirc actuator. I haven't read my manual yet to see if its accessible for removal yet. If I do remove it, I would probably tear it apart and post snapshots and determine if a gear broke, stripped, motor died or if any circuitry failed. I haven't checked if these actuators are the same ones used in recirc, mode and temperature.
Old 08-07-2020, 09:07 AM   #23
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Looks like the ebay seller listed a couple more;
https://www.ebay.com/itm/12428235216...2166#vi-ilComp
2002 L300 Sedan
2003 L300 Wagon
2005 L300 Sedan
Old 08-08-2020, 07:51 AM   #24
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default Re: the old mode actuator trick in the hvac .the war continues
hi ibraner and fdryer- looked at the additional posting for the actuator. also saw the new gear posted too. plan to take out the original gearbox and check the gear . that may solve the problem. a pileup of surprise brushfires and clusterf@!#ks have savaged my available time for this job. will have to delay it for a while . ac does work well out the front vents if i leave it alone. but will need defrost function in the fall. will keep in touch. btw how many pins in the male connector boss on the actuator identify the one for the L 100. on the many actuators for gm cars they range from 2 to 6 . some are set up in 2-3 order or 3-2 order. appreciate your ongoing help. bob f
HVAC actuator issues spizwhit Vue Tech 0 12-10-2019 03:48 PM
Failed mode actuator JoeGeds Vue Tech 2 10-28-2017 02:15 PM
Tips/Trick for LED Instrument Cluster & HVAC Upgrade cme1st2302 Vue Mods 6 07-07-2016 12:16 PM
HVAC Actuator Question jfitzi33 L-Series Tech 2 06-28-2015 12:59 PM
HVAC module/actuator DanB98TJ S-Series General 0 07-20-2006 01:17 PM
