Old 07-31-2020, 05:43 PM   #1
timl865
timl865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to beholdtiml865 is a splendid one to behold
Default Removing knuckle, need socket sizes
hi, I'm heading to the upull tomorrow and need to know what size sockets I need to pull a pass knuckel. I think its 18mm for the strut bolts.. but that's all I remember. I cant remember what the tie rod and lower ball joint size is... Any help greatly appreciated!
timl865 is offline   Reply With Quote
Old 08-01-2020, 09:05 PM   #2
Default Re: Removing knuckle, need socket sizes
The large majority of bolt and nut hex sizes for suspension parts under our L's are indeed 18mm. I can't recall the hex size for the tie rod ends nor the ball joints although I've worked on both in the past. Nevertheless, if it were me I would bring along 19mm tools and larger if I had them. Better safe than sorry...(IIRC, there may be something that's 16mm as well.)
It would be ideal if you were using a 1/2" drive ratchet and sockets on all suspension parts where this is possible, but especially at the ball joint. The ball joint has a through bolt and nut on the other end so you'll need two tools to loosen them until they're separated.
338,000 miles - Holy canolli!
Old 08-02-2020, 01:11 AM   #3
02 LW300
02 LW300's Avatar
Donít forget the big nut on the axle. 1 1/4 or so, I honestly donít remember the size.
2002 L200/5 loaded, coming attractions B207R and F40, Ion Redline axles will make this work.
Old 08-06-2020, 01:13 AM   #4
FWIW, I believe that the nut holding the drive axle in place at the hub is 30mm. Yea, I know it's a late reply.
Anyone know where to buy reverse light socket and turn signal socket? solidhadriel S-Series General 3 08-29-2014 01:05 PM
Removing Hub from Knuckle - 94 SC2 wscreate S-Series Tech 0 10-07-2009 01:50 PM
Deep socket sizes used? phosho S-Series General 8 04-01-2009 10:43 AM
Help with removing cigarette lighter socket mr18436572 S-Series General 2 03-11-2008 11:32 PM
need knuckle, control arm 97 sc2 Bleay S-Series Tech 1 06-10-2006 12:03 AM
