Old 07-17-2020, 04:59 AM   #1
SnowZilla
SnowZilla is on a distinguished road
Default Trunk Hatch release from inside and lights off if open and not shut all the way
I want to be able to open the hatch from the inside once its shut without getting out of the car. Sort of like an emergency trunk release. Is there a mod, or switch I can install or a feature I id not know about.
2nd the front head dome driver&passenger lights stay on if I have the liftgate up. I done a bad workaround where I unclipped the cover and wedged something on the switches to leave them halfway. But I would like more elegant solution.
I'm aware I can move the latch manually on the hatch from reading previous posts, but I want a solution where I can just shut it off.
Is there a fuse I can pull yet retain functionality of the lights? Wire to snip that would still let me turn on the lights manually?
Perhaps soldering a switch?
SnowZilla is offline   Reply With Quote
Old 07-19-2020, 10:21 AM   #2
atikovi
Default Re: Trunk Hatch release from inside and lights off if open and not shut all the way
Pretty sure the dome light goes off automatically after 15-20 minutes if you leave a door or hatch open.
Old 07-20-2020, 03:16 PM   #3
SnowZilla
I should mention this a 2004. I did test about 30min with hatch open and my lights did not go off. Either way I need it to go off right away.
For the trunk/hatch release, if I drilled a hole perhaps is there a way to unlatch it from the inside then.
Perhaps someone has a wiring diagram I can disable the light from there as well?
Old 07-20-2020, 07:29 PM   #4
Bruce Rock
Bruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the rough
2000 SL2
2006 VUE 2.2L
From my 2006 owners manual:
Battery Run-Down Protection Your vehicle is equipped with a battery saver feature designed to protect your vehicle’s battery.When any interior lamp is left on and the ignition is turned off, the battery rundown protection system will automatically turn the lamp off after 20 minutes. This will avoid draining the battery.
I'm on the fence about this feature actually working.
Old 07-20-2020, 07:50 PM   #5
atikovi
Works on mine. Leave the hatch open for hours to access tools and the light is off.
Old 07-23-2020, 01:56 PM   #6
SnowZilla
Is there a fuse I can pull or a wire I can just cut?
For the hatch ultimately what I want is.
Lets say I had a cage barricade blocking someone from the 4 doors. Then I locked someone in the cargo area. I want an internal latch release system so that whomever is in that area can release themselves without waiting for someone to open the hatch. I also don't want to trigger the lights.
1997 SL2 trunk won't stay open, slams shut AltxF4 S-Series General 8 07-29-2016 05:36 PM
Inside trunk release unkle bik L-Series Tech 14 06-28-2016 12:51 PM
Rear Hatch (Trunk) will not open sometimes Articwhite2008 Astra General 1 03-12-2014 10:02 PM
Can't open trunk from inside karinhesed86 S-Series General 8 06-19-2006 03:33 PM
Trunk Release - Inside! saturncanuck General Saturn Discussion 4 10-02-2000 07:48 PM
