Old 07-07-2020, 05:46 PM   #1
Cavell
2003 VUE 3.0L
Default Rack preload
I have noisy front end. Did all the struts, mounts, sway bar stuff. Caliper guide pins too. So, 1 vue is silent. My 2nd vue is noisy when I wiggle the steering wheel. No, it’s not the intermediate shaft. I have a rattle over bumps in road. I think it is the rack. read you can adjust rack preload. Vs replacing rack? Think is a thing to investigate?
Old 07-07-2020, 08:14 PM   #2
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Default Re: Rack preload
Rack preload is not adjustable. This could either be noise from the rack or some of the early model Vues had issues with too wide of a gear lash between the gears in the steering motor. The only fix was to replace the electric motor. Something to check though is where the rag joint is by the stub shaft coming off the electric motor. It has a pinch bolt securing the joint to the stub shaft. Some of those I saw cause a rattle noise over bumps or uneven pavement from the bolt not being completely tight. Mostly I saw that on 04-05 Vues and not on the older ones, something simple to check though.
Old 07-07-2020, 09:29 PM   #3
Cavell
2003 VUE 3.0L
I compared both rigs. Both have same noise from boost unit under dash. Which I think is minor. I think the real noise is from the rack
Old 07-15-2020, 06:52 PM   #4
Cavell
2003 VUE 3.0L
Saw a video of guy who removed knuckle assy thru firewall and he had click from power unit when he turned steering wheel. Sound was coming from boost unit and he was puzzled. Thatís why I see boost units removed from junkyard vues. For internal gear slop noise?
'00 LW2 Steering Preload Spring txzaphod L-Series Tech 3 01-07-2013 04:32 PM
Steering rack replacement: bearing preload adjustment? PlasticCarsRock S-Series Tech 4 05-09-2010 03:04 PM
Steering Gear Preload Adjuster Spring beensmoked L-Series General 5 12-21-2004 06:43 PM
Saturn L PreLoad Spring in Steering Euphony010 Miscellaneous Tech 7 08-17-2004 12:25 AM
Help adjusting preload on manual rack! ProDarwin S-Series Tech 7 08-01-2003 04:03 PM
