Old 07-21-2020, 03:26 PM   #1
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default the old mode actuator trick in the hvac
hi sages- looking for source of a part and having no luck in america. hoping one here smarter than me has one on a shelf in their garage or knows a source. the part is called the mode actuator control and is on the right side dial in the hvac control module of my saturn L !00. it controls the direction of the air flow to the floor or occupants faces or windshield or a combination thereto it also switches the ac on if you direct the air to defrost. i had the whole module out last year to replace the 5 position blower fan speed switch in the top center of the module.the mode actuator part number is 22732653 . surprised i cant find it anywhere since i would think other gm models of similar size to the saturn L might interchange. so what do you think can you help a poor guy from jersey? thanks tons bob f
Old 07-21-2020, 03:49 PM   #2
lrbraner
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default Re: the old mode actuator trick in the hvac
2040-parts.com shows it as available. $50.
I know nothing about the site.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 07-21-2020, 03:53 PM   #3
lrbraner
ebay has a used one for $35 ish.
They also list a Dorman part number, Dorman 604195
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 07-21-2020, 04:00 PM   #4
lrbraner
Upon checking further I dont believe the Dorman number is good for the L series.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 07-22-2020, 09:44 AM   #5
rfisher
hi ibran- looks like curtains for this function. tried dorman, rockauto, 2040 and no soap. 2040 did have a used complete hvac module for an L for 38. mechanic pro tried for me too and stinko results. looks like the dial switch on the module signals a pair of motors behind the glove box which actuate the air direction doors. front dash vents now blow good cold air blast . that is the only position that works on the dial which is at 7oclock low which is ok for the long heat wave in fla, but no good for the cooler/defroster season in jan. will try carid for it . ebay was ng. also will try junkyard. any other ideas/sources? thanks tons bob f
Old 07-22-2020, 10:22 AM   #6
lrbraner
There is one on ebay. Search using only the part number and check the box that says to include descriptions in the search.
The listing number is 124026364094. you can search for the listing number as well.
Link;
https://www.ebay.com/itm/Saturn-LW-L...wM-n#vi-ilComp
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
HVAC actuator issues spizwhit Vue Tech 0 12-10-2019 03:48 PM
Failed mode actuator JoeGeds Vue Tech 2 10-28-2017 02:15 PM
Tips/Trick for LED Instrument Cluster & HVAC Upgrade cme1st2302 Vue Mods 6 07-07-2016 12:16 PM
HVAC Actuator Question jfitzi33 L-Series Tech 2 06-28-2015 12:59 PM
HVAC module/actuator DanB98TJ S-Series General 0 07-20-2006 01:17 PM
