Old 09-27-2013, 07:52 PM   #1
DCAstraFan
DCAstraFan is on a distinguished road
Default Alternator replacement
I have just replaced my alternator and it was a bear. Maybe I did it incorrectly, but I think it was the easiest, but certainly not easy. The alternator is fairly easy to get loose from the engine. But it is impossible to get the alternator out of the engine bay because the clearance is insufficient.
The initial thought was to remove the engine mount and try wedging the engine out of the way. But that seemed pretty substantial and risky. So I decided that I would disassemble the alternator in the bay and remove by pieces. Also disassembled the rebuilt alternator to get it in. It was tough and exhausting, but it worked and it was satisfying.
Anyhow, just thought I'd share.
DCAstraFan is offline   Reply With Quote
Old 10-04-2013, 11:27 PM   #2
nrramse
nrramse is on a distinguished road
nrramse's Avatar
2008 Astra XE
Default Re: Alternator replacement
Thanks for the posting, and welcome to the board!
I think all automotive engineers should be made to serve as technicians for a length of time so they know to make things like alternators a little easier to get to.
2008 Astra XE, 5 speed stick
nrramse is offline   Reply With Quote
Old 10-12-2013, 12:11 AM   #3
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
Just for future reference the way to get it out is to remove the passenger side engine mount while the engine is supported by a floor jack. Then you remove the alternator out the opening in the wheel well (remove front passenger tire and plastic fender panels) as you raise and lower the engine just enough to get it out. It won't come out if the engine is lowered all the way and won't come out if it is up all the way. There is a sweet spot right inbetween high and low where if you rotate it the correct way it will come out.
smwalker is offline   Reply With Quote
Old 09-03-2015, 08:53 AM   #4
bigbl5
bigbl5 will become famous soon enough
I know this is an old thread, but I thought I would add my procedure in case someone else has this issue. Just for reference, mine was a 2008 Astra XE.
1. Disconnect battery
2. Remove air box and hoses.
3. Release tension on tensioner and remove belt from alternator
4. Lift passenger side front and remove tire.
5. Remove two bolts holding alternator (11mm 12pt)
6. Remove alternator from engine. This will probably be a little tight as the alternator threaded nuts pull tight against the mounts... a little prying and the alternator will come off.
7. Remove the nut holding the power wire and the electrical connector. This is a massive PITA. The wires aren't long enough so a lot of this is done blind. Plus the little electrical connector has a locking tab that is difficult to remove. Mine, of course, broke the little tab and I had to blindly use a screw driver to pry the tab out.
8. There was no way the alternator is coming out the top of the engine bay, so don't waste an hour trying. The key, as the other poster above stated, is to take it out thru the wheel well. I didn't have to monkey with the engine mount at all. What I did is to angle the alternator so the pulley is pointing toward the wheel well and slightly forward and slightly down. The flat part of the alternator should be on the upper right and the bolt holes should be in roughly the 10 o'clock and 4 o'clock position. The alternator will just barely fit thru the wheel well. I didn't even have to remove the splash shield.
9. Reinstall in reverse order obviously.
bigbl5 is offline   Reply With Quote
Old 09-03-2015, 09:57 AM   #5
AstraFasta
Bigbl,
How many miles did your car have? How long did the alternator removal take?
AstraFasta is online now   Reply With Quote
Old 09-17-2015, 12:59 PM   #6
Burgandy25
Burgandy25 has a spectacular aura aboutBurgandy25 has a spectacular aura aboutBurgandy25 has a spectacular aura about
This is funny because on the official instructions to remove the alternator it says to remove the engine mount/support.
Burgandy25 is offline   Reply With Quote
alternator, replace
alternator replacement Amp67 S-Series Tech 10 01-17-2009 05:59 PM
alternator replacement rxdeath S-Series Tech 8 03-14-2007 10:54 PM
alternator replacement DHOOP S-Series General 12 09-09-2004 12:14 PM
alternator replacement digitalpimp2007 S-Series Tech 3 07-27-2004 03:01 PM
Q: 99 SC1 Alternator replacement RobertHammen S-Series Tech 5 12-21-2003 08:20 AM
