Old 01-09-2010, 12:50 AM   #1
eriklane
eriklane is on a distinguished road
Default 2001 SL1 High idle - cant get ECTS clip off
149k on my good SL1. 3k idle in park, 1300 while stopped at light. Sprayed cleaner in TB and replaced IAC. Will take TB off and fully clean tomorrow. Start/off/restart doesn't help. Sprayed brake cleaner on all intakes, nothing. Have thermostat to replace also tomorrow what the hek. Have new TPC if needed also. Can't get the clip off the ECTS. Cream color-delicate-don't dare horse it. How do I get it apart?
Car runs great otherwise. Please help.
Add to eriklane's Reputation
Rate the quality of this post and help eriklane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eriklane is offline   Reply With Quote
Old 01-09-2010, 01:00 AM   #2
Default Re: 2001 SL1 High idle - cant get ECTS clip off
The ECTS connector has a black part that is attached to the white top where the 2 wires enter. On the bottom, closest to the head, there are 2 ears on the black section. Squeeze in on them and it will slip off with no force. The ears are longer than the surrounding part. You can feel them if you are careful.
Old 01-09-2010, 01:16 AM   #3
eriklane
I put a needle nose in there and did squeeze but nothing. I can't hardly get my fingers in there, but will retry gently tomorrow with needle nose or redo with fingers...wish me luck.
Old 01-09-2010, 01:30 AM   #4
Needle nose squeeze the wrong end, have to use fingers. Stick one in there and locate one of the ears, the other one is on the other side. Then just pinch the ears. You are right, there is next to no room. Do not trash the connector, its $30.00 or so to replace from the dealer.
Old 01-09-2010, 10:22 AM   #5
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Here is what you are up against.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-09-2010, 10:34 AM   #6
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Those have to be the cleanest hands ever for a mechanic. Richpin, you truely are a surgeon and thanks for all the help. (I realize you had to dress them up a little for the photo shoot). Keep up the good work.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 01-09-2010, 10:34 AM   #7
Thumbs Up Re: 2001 SL1 High idle - cant get ECTS clip off
Picture is worth a thousand words!
Old 01-09-2010, 11:25 AM   #8
Signmaster
What I liked most about this great photo is knowing that the gap to put your fingers in to squeeze the "ears" is about 1/3 the size of the average mans finger.
Old 01-09-2010, 01:26 PM   #9
3000 RPM idle, gen-3 SOHC ===> intake manifold gasket leak. Start it up and spray brake cleaner along the mating edge between the intake manifold and the cylinder head, esp. around the #1 runner. If the idle changes, there's your trouble.
Add to madpogue's Reputation
Old 01-09-2010, 08:32 PM   #10
eriklane
Yep-confirmed it. I sprayed on #1 and instantly it changed. Out in 12 degrees doing the manifold right now...Also, cleaned the Throttle body-found the IAC pintle had unscrewed (?) from the shaft-was lodged in the TB. Quickly screwed it back on and cleaned everything - huge amount of crud...
Thanks everyone. I had sprayed but not close enough-and it was a very specific spot on the mani where, once the spray hit, it dropped instantly...
Happy now-$21 and I'm good...
Old 01-09-2010, 09:09 PM   #11
Sounds like you now have it all fixed. Might want to dig up another IAC or locktite that one together as the vibration and air stream will eventually take it apart again.
Old 01-09-2010, 10:14 PM   #12
eriklane
It's a new one. Now struggling to get the mani off-left side by pwr strng wont come apart...
Old 01-09-2010, 10:53 PM   #13
look underneath for a bracket attached to the lower part of the manifold that runs down to the drive axle intermediate shaft. And take off the upper bracket for the power steering.
Old 01-09-2010, 11:03 PM   #14
Should not be any brackets on a SOHC. There are 9 studs holding the manifold.
Old 01-09-2010, 11:08 PM   #15
Here is the answer. Power steering pump has to come back about 1/4 to 1/2 inch for clearance.
http://www.saturnfans.com/forums/sho...ntake+manifold
Old 01-10-2010, 04:57 PM   #16
eriklane
Got the job done, thanks to a post that says there are 9 (nine) N I N E manifold nuts, not 8....whodathunkit? I kept wondering-what is hanging it up on the left? Geez.
Get a long magnetic tool-use it to hold the nuts when taking off and when putting back on-lifesaver...also, I had to take the fuel intake to the manifold off-when pushing the mani back, it got hung up on that.
Cleared the codes,she's idling at 900 warm. HUGE SMILE, fist pump, chest bump, woo hoos.
Thanks to all of you...Snowmobile suited in 15 degrees here in MI...
Oh, the manifold on cyl 1 was shot-not even all there... huge wrinkles...quite something-considering it went 149k before it finally got bad...
Old 01-10-2010, 05:00 PM   #17
At least its done and now you can thaw out.
High idle problems 2001 SL1 thevaledic S-Series Tech 5 05-08-2009 04:37 PM
95 SL1 High Idle. New ECTS/Thermostat. Anything Else?? AceDerry2 S-Series Tech 6 02-03-2007 09:11 AM
2001 SL1 high idle after cleaning Throttle Body rickystarshine S-Series Tech 6 11-19-2006 09:33 AM
ects replaced, high idle continues shaner123 S-Series General 18 12-12-2005 10:07 PM
94SL1 High Idle with new ECTS flapjabby S-Series General 15 10-22-2005 08:28 AM
