Old 06-01-2004, 06:18 PM   #41
vtunderground
vtunderground is on a distinguished road
vtunderground's Avatar
Default
Well, I did the MMO soak the other week. Right off, I noticed that my fuel economy was suffering... it was about 10mpg lower than what it should have been. It quickly recovered, but I was really worried for a couple of days.
Anyways, my oil consumption has, if anything, gotten worse. Stupid Saturn, maybe a second MMO soak will do the trick.
Oh what is Seafoam, and where can I get it?
Add to vtunderground's Reputation
Rate the quality of this post and help vtunderground reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vtunderground is offline
Old 06-02-2004, 01:50 PM   #42
lhanna
lhanna is on a distinguished road
Thumbs Up
I completed my first MMO soak yesterday. I let the MMO stay in the cylinders for about 18 hours. It all leaked out of the #1 cylinder after about 4 hours (I refilled it) and #'s 2 ~ 4 sometime after that.
I was due for an oil change so I went ahead and did that and added Techron to the fuel tank.
The engine performance has obviousley improved but I can't judge oil consumption yet.
After reading about the MMO soak, I was expecting the car to be hard to start and to produce a lot of smoke. However the car started instantly & smoothly and produced no smoke at all.
Add to lhanna's Reputation
Rate the quality of this post and help lhanna reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lhanna is offline
Old 06-02-2004, 02:21 PM   #43
Spazie
Spazie will become famous soon enough
Spazie's Avatar
1993 SC2
Default
Most not have left it in long enough. The smoke is tons of fun!
13 Chevy Equinox, 46k, built in Spring Hill!
04 VUE 3.5, 196k
99 SL2 Homecoming, 211k
Add to Spazie's Reputation
Rate the quality of this post and help Spazie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spazie is offline
Old 06-02-2004, 08:55 PM   #44
lhanna
Default
I'm afraid I can't do more than 18 hours. I'll try again another day.
lhanna is offline
Old 06-04-2004, 01:07 PM   #45
Spazie
Spazie's Avatar
1993 SC2
Default
Woohoo!!
29.1 mpg on the last tank. My best ever! Though only by about .6 mpg. However, it was a mostly city, which usually drops my mpg to 26. So maybe when it's mostly highway miles, it'll go up above 30! I don't know if this is a result of the MMO or the new header, but something's working!
04 VUE 3.5, 196k
Spazie is offline
Old 06-05-2004, 03:59 PM   #46
geartooth94
geartooth94's Avatar
Default
what hasn't been addressed in this thread yet is what to do in case all the MMO seeps down past the piston rings into the engine.
Refill as soon as you notice and then start the car, or wait for a while?
Anyone have an answer?
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline
Old 06-05-2004, 06:17 PM   #47
GNA Trojans
GNA Trojans is on a distinguished road
Default
Well I did the MMO soak about 20 days ago. Seems like i am burning more oil. To hard to tell yet. I am goin to do one more soak, and dump the rest of the MMO in with the oil and change out after 200 miles. My gas milage is great, just hate seeing the smoke when you hit the high revs and need to get on it. Maybe there is damage to the motor and the MMO will not help it.
Add to GNA Trojans's Reputation
Rate the quality of this post and help GNA Trojans reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GNA Trojans is offline
Old 06-05-2004, 11:58 PM   #48
sierrap615
sierrap615's Avatar
Default
i was wondering that myself, both mmo and seafoam seem a bit thin, would something thicker(which would need to sit longer) work better, or am i trying to reinvent the wheel?
also, i thinking about rebuilding with "total seal" gapless rings will the MMO soak still work? or would it not even get past the first ring?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 06-07-2004, 01:34 PM   #49
freakerz
freakerz is on a distinguished road
freakerz's Avatar
Default
Hi,
I just did my compression test on my SL1 1993 with 242 000KM:
Passenger to Driver
160 195 185 195
180
the 180 was after I poured tsp of oil.. so I guess a MMO soak would fix everything up to 195?? or even more > (DO I HEAR TURBO!!!!) >;'\\\\
I do 500KM with a full tank of gas.. and I use a full pan of oil.. in about 4-5 tanks of gas.. is that in the norm or best or worst?
Add to freakerz's Reputation
Rate the quality of this post and help freakerz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freakerz is offline
Old 06-08-2004, 02:34 AM   #50
sierrap615
sierrap615's Avatar
Default
the MMO may help, but for a turbo on a high mileage motor, you should rebuild first.
4 quarts of oil in 2500KM? ( i think thats about 1200 miles ) thats not very good, 1 quart in 2000 miles (maybe 4500 or 5000 KM?) is normal
Old 06-08-2004, 12:48 PM   #51
freakerz
freakerz's Avatar
Default
i guess i'll have to check.. but it doesnt use alot of oil..
freakerz is offline
Old 06-11-2004, 11:06 AM   #52
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Post
2,500 kilometers = 1,553.4279806 miles.
Anyway, it sounds like freakerz is burning about 1 quart of oil per tankful of gasoline. That sounds excessive to me.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 06-11-2004, 04:42 PM   #53
GNA Trojans
Default
Yea try 1 quart every 500 miles. That is what is burning on my 98 sc2. Funny part is i never see any kind of smoke on start up or when i am driving. Where it is going i have no clue.
Old 06-11-2004, 05:57 PM   #54
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Idea
Maybe one or more of the gaskets on the engine (for the oil pan, for the valve cover, etc.) is leaking? If you look at the underside of the engine, do you see things that are covered with dirty oil and/or grime?
My 1993 SL2 was "consuming" about 1.5 quarts of oil per 3,000 miles. Then I changed the valve cover gasket and have since driven 2,000 miles; the oil level is down only 1/4 quart. Yes, I had oil around the spark plug wires on the top of the valve cover and I had oil on the sides of the engine that face the firewall and that face the battery. After I changed the valve cover gasket I cleaned up the engine compartment with Simple Green, a toothbrush, and water trickling out of the garden hose. All of those areas are still clean today.
My 1996 SC2 "consumed" oil at a greater rate than my 1993 SL2. On this car the back of the engine, the transmission, and a few other things were always wet with oil. The valve cover gasket was less than 50,000 miles old so it was probably another gasket or two that needed to be replaced. But the clutch was beginning to slip so I wasn't anxious to dump too much money into that car at that point.
Neither car has/had visible smoke exiting the tailpipe except when under wide open throttle and shifting at high RPMs. For the most part I shift before 3,000 RPM.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 06-12-2004, 12:23 AM   #55
GNA Trojans
Default
Valve cover gasket changed, No leaks under car, no puddles. MMO soak was done 1,000 miles ago. It has to be something internal.
Old 06-12-2004, 07:46 AM   #56
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Red Face
Mine never had any oil drip marks on the ground either. Probably the oil only leaked out of mine while the engine was running, and I'd guess the higher the RPMs the greater the rate of oil leaking.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 06-14-2004, 12:59 AM   #57
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default
My car has some oil around the bottom near the oil pan. I've never seen it dripping or anything but I do park in the dirt. The oil level seems farely consistent right now but I haven't had it for very long.
I do see a little bit of some under WOT though. Maybe the MMO soak will help with that....hopefully. People might laugh at me at the track.
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 07-15-2004, 08:08 PM   #58
acid-reflex03
acid-reflex03 is on a distinguished road
Default
After doing the soak, do I have to change the oil right after, or would it be fine to run the last ~1500 miles on this oilchange? Thanks.
Add to acid-reflex03's Reputation
Rate the quality of this post and help acid-reflex03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acid-reflex03 is offline
Old 07-16-2004, 12:11 AM   #59
sierrap615
sierrap615's Avatar
Default
depends how bad the rings are, best to do a oil change about 50 or 100 miles after, not much more
Old 07-16-2004, 12:13 AM   #60
acid-reflex03
Default
OK. I'll do the oil change in about 100 miles. Should I add the last 12oz of MMO to the crankcase after it starts up?
mmo piston soak saturnsctwo S-Series General 9 03-11-2006 06:31 PM
I did the MMO piston soak... 98greenSC2 S-Series Tech 2 10-03-2005 02:28 PM
what is a MMO Piston Soak SaturnPower93 S-Series General 1 02-21-2005 10:37 PM
MMO Piston Soak... 93BLKTWINCAM Miscellaneous Tech 1 02-20-2004 05:37 AM
MMO piston soak (and soak, and soak...) David 93 SL2m S-Series Tech 9 02-19-2003 11:51 AM
