Old 02-12-2007, 04:05 PM   #1
99_sl2
99_sl2 is on a distinguished road
Default '99 DOHC Rebuild
im planning to rebuild my saturn motor due to a spun rod bearing. does anyone have experience in doing this as far as finding parts and what parts i will actually need. i have a good list goin already but im dreading dealing with the morons at the auto parts store. here's everything i have down so far. anyone feel free to let me know if i've missed anything.
Crank
Rod
Main Bearings, Rod Bearings
Piston Rings
Head Gasket
Front/Rear Seals
Spark Plugs
Belt
Oil Filter
Intake/Exhaust Gaskets(are these reusable or should i get new ones)
Timing Chain Tensioner?
Valve Stem Seals
also, does anyone know if i can get a piston/rod assembly or if i have to buy the rod separate. or if the wrist pins are press on or have clips? thanks in advance for any help
Add to 99_sl2's Reputation
Rate the quality of this post and help 99_sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99_sl2 is offline   Reply With Quote
Old 02-13-2007, 02:27 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: '99 DOHC Rebuild
Since there were significant engine changes in the DOHC engine between 1998 and 1999, I would suggest telling the parts people that you need these parts for a 2000 (uses same parts as 1999) to ensure you get the right parts. I find all too often when I shop elsewhere that most parts people take the data in the computer as gospel ("Not Available" on the screen means not available period dammit!!! lol) and are usually too lazy to check the book. Being an ASE Certified parts specialist myself, I encounter data errors in our parts look-up computer more often than I would prefer, but some human error during data transfer (from the book to the computer) is inevitable. If I sense the potential for a certain part to be listed wrong in the computer I verify it with the book. It is safe to say that the part books are correct 99.9% of the time.
I would add a timing set (includes chain and sprockets) to your list. The intake and exhaust gaskets are not reusable and I would replace both. Don't know about the pistons/rods.
2007 Ion 2 Quad Coupe 5-speed manual 181K miles
2007 Chevy Equinox LT 192K miles
2018 Chrysler Pacifica Touring L 31K miles
Add to ruley73's Reputation
Old 02-13-2007, 03:25 AM   #3
99_sl2
hmm...thank you...also, after reading some other posts....is it absolutely necessary for a new oil pump and new timing chain and everything?...the motor only has about 80,000 on it
Old 02-13-2007, 04:21 AM   #4
remedys
remedys is on a distinguished road
remedys's Avatar
2001 SC1
For the cost of those parts it would be worth it. Better to do it now and save on the time later. I changed my motor last summer and had to replace my clutch two weeks later. That was 200 bucks I didn't want to or have to spend
SC1, DOHC swap, Nitrous wet kit, expressions lip kit, 2" drop, 17" konigs, full exhaust.
Add to remedys's Reputation
Rate the quality of this post and help remedys reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
remedys is offline   Reply With Quote
Old 02-13-2007, 07:00 AM   #5
BarnOwl
BarnOwl's Avatar
It's extremely rare for an oil pump to go in these cars. I would get a timing set from Saturn though. Pack the oil pump with petroleum jelly before you put things back together.
Add to BarnOwl's Reputation
Old 02-13-2007, 04:22 PM   #6
99_sl2
alright, yeah, i understand the timing chain and all, timing chains are not fun to do, been there...also, i can pull the motor out the top correct?...its a manual trans...does the tranny have to come out with it, or will i separate them?.....oh, and why pack the oil pump with petroleum jelly? just lubrication, or to keep debris out?...why?..i've never heard of doing that before
Old 02-13-2007, 08:11 PM   #7
saturnhouse
saturnhouse will become famous soon enough
The petroleum jelly "primes" the pump. It ensures that it creates enough suction to start pulling oil up from the pan. If you start out with a new oil pump that's not full of something... (and you wouldn't want to try to keep oil in there while putting everything together)... it'll won't draw any oil, and your engine will be running without lubrication.
I've never pulled an engine on a Satty, but I hear that its easier to drop the whole thing out the bottom. There are threads in here that have a lot of detail, if you search around.
Add to saturnhouse's Reputation
Rate the quality of this post and help saturnhouse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnhouse is offline   Reply With Quote
1.9L DOHC rebuild kit.... saturn_69 S-Series Tech 11 11-03-2011 10:22 AM
95 1.9L DOHC Rebuild - THANKS Canyon S-Series Tech 0 08-23-2008 11:23 AM
DOHC Rebuild Ryan from Ohio S-Series Tech 28 03-04-2007 10:37 PM
ARi's DOHC Rebuild sps SOHC S-Series Tech 84 03-28-2005 10:42 PM
DOHC Rebuild Part numbers! sps SOHC S-Series Tech 6 02-27-2005 12:55 AM
