Old 10-08-2018, 01:34 PM   #1
Jski
Jski is on a distinguished road
Wrench 2006 Vue Red Line w/Honda 3.5l compressor
Hi Friends, I found a puddle under my Vue it has 100,900 mi. on it I recently had an oil change done and thought that's what was leaking. So I took it back and the said the compressor was soaked and leaking. I also noticed when driving my gas mileage has also dropped off about 6mpg. So I could see if the compressor is dragging that makes sense. Can anyone tell me how hard of a job it is to replace the system, or reccomend where to get it serviced and what a ballpark price is I'm located on the South side of Chicago. TIA
Add to Jski's Reputation
Rate the quality of this post and help Jski reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jski is offline   Reply With Quote
Old 10-13-2018, 10:49 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 2006 Vue Red Line w/Honda 3.5l compressor
How big of a puddle? There is not much oil in the AC system. And if it did leak out the refrigerant oil, it also leaked out the refrigerant. The resulting low pressure would stop the Compressor Clutch from engaging, so it's not likely there would be a drag on the engine. I would do some more investigating.
Add to Chazberry's Reputation
2006 Ion ac compressor replacement Drillerguy Ion Tech 1 08-28-2018 04:39 PM
2006 3.5 Honda cuts fuel off (??) at 3500 rpm newbievueowner Vue Tech 4 02-26-2018 11:37 PM
2006 VUE - AC Compressor jpdavis44 Vue Tech 11 09-25-2016 02:18 PM
A/C line seals at compressor RobertGary1 S-Series Tech 4 10-11-2011 10:03 PM
2006 Vue a/c compressor fail? Sportymommel Vue Tech 4 07-19-2011 04:25 PM
