Old 10-05-2018, 01:17 AM   #1
MDB
MDB is on a distinguished road
Dizzy 2002 Vue V-6 Slow Acceleration
Hello all. I had to remove the intake on my daughters Vue, to work on it. I installed new intake gaskets, torqued the bolts to spec, and re-installed the rest of the components. After this, the car has to turn over for a few seconds before starting. Also, the car has slow acceleration now. When you put the accelerator to the floor, it has the sound of a four barrel but accelerated slowly. I removed the intake and reinstalled, thinking maybe I had a vacuum leak, but that didnít solve the problem. Itís almost as if the intake flappers are not closing during initial acceleration. Any thoughts on this issue will be greatly appreciated. Thank you.
Add to MDB's Reputation
Rate the quality of this post and help MDB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MDB is offline   Reply With Quote
Old 10-05-2018, 10:25 AM   #2
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
2006 VUE Red Line
Default Re: 2002 Vue V-6 Slow Acceleration
Is the check engine light on? Not sure if disconnecting the electronic throttle body would cause this sort of issue.
'02 SL1 [w/ a snail-shaped muffler]
'06 Vue RL
Saturn Night is Special ED.
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 10-05-2018, 03:35 PM   #3
Cavell
i have removed my kids intake 4-5 times. timing belt, valve cover gaskets 3 times. and thermostat once. still on original intake gaskets. i did leave the TB unplugged last time. uh, got a CEL and reduced power for that. oops. the TB only has 1 plug. the maf has a plug by the airbox. both are easy to see/reach.
Add to Cavell's Reputation
Old 09-23-2019, 10:22 AM   #4
raiderpt1
raiderpt1 is on a distinguished road
2002 VUE 3.0L
i'm having the same issue now on my 03 vue after replacing leaky oil cooler. what was the resolution ?
Add to raiderpt1's Reputation
Rate the quality of this post and help raiderpt1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raiderpt1 is offline   Reply With Quote
Slow Acceleration? MetalMatty S-Series Tech 7 07-31-2013 10:16 AM
Slow Acceleration 2007 Saturn ION SaturnIONSLVUE Ion Tech 1 01-07-2013 12:28 AM
Sl-2 problems, overheat, slow acceleration Arakami S-Series Tech 1 05-26-2009 10:19 AM
96 SL2 shuddering - slow acceleration insane_drummer S-Series Tech 51 07-21-2007 06:03 PM
Slow Acceleration and Oil Consumption OR1 S-Series General 11 10-18-2005 02:12 PM
