Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 08-27-2016, 11:58 PM   #1
tdubdub
tdubdub is on a distinguished road
Default timing belt at 75K/12 YRS
Getting my 1 owner 2005 FWD Redline ready to sell so thought I should do timing belt/water pump aisin kit since belt was 11+ years old. The car has been in Socal all its life and never used for towing. The belt and water pump were both still excellent. Belt showed no cracking or teeth deterioration. Just wanted to post as a FYI for those contemplating the maintenance.
Add to tdubdub's Reputation
Rate the quality of this post and help tdubdub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tdubdub is offline   Reply With Quote
Old 09-05-2016, 01:34 PM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: timing belt at 75K/12 YRS
Thanks for an informative thread ... if you do sell your Vue - the new owner will obviously be getting a well cared for ride.
I don't spend much time on forum but do answer private messages (they alert my phone). Include email address if you need pdf extracts. Don't use visitor message feature as I forget to check those.
Old 10-12-2018, 04:53 AM   #3
Tobacconist
Tobacconist is on a distinguished road
On most modern cars it is rarely the belts that fail, but rather the bearings that fail. The are sealed and the grease slowly starts to break down.
Add to Tobacconist's Reputation
Rate the quality of this post and help Tobacconist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tobacconist is offline   Reply With Quote
Old 10-14-2018, 06:27 PM   #4
Vue6
Vue6's Avatar
2006 VUE Red Line
...NOT TRUE, I HAVE A BELT THAT HAD ALOT OF CRACKS IN IT AT 100 THOUSAND MILES IN ANOTHER VEHICLE. PUT EVERYTHING NEW BACK IN IT, COMPLETE KIT, AND 50,000 MILES LATER THE BELT SHREDDED AND PULLED APART.PUT A NEW BELT IN IT AGAIN, AND AT 167,000 MILES IT IS STILL GOIN, KNOCK ON WOOD, LOL, DC
Add to Vue6's Reputation
Rate the quality of this post and help Vue6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-15-2018, 09:51 PM   #5
Tobacconist
I never stated that in was true for every case 100% of the time.
I simply stated that after seeing and reading about many timing-belt failures, it is one of the pulley bearings that fails which causes the timing-belt jump.
The service life of a quality timing-belt usually exceeds that of a sealed bearing.
Old 10-16-2018, 07:30 AM   #6
waiter21
2003 VUE 2.2L
If it was my Vue. I'd change it..
This is what I consider a "low risk, high consequence" item. I might be able to get 25k miles more out of it, but if it fails, the consequences are a destroyed engine.
Add to waiter21's Reputation
waiter21 is online now   Reply With Quote
Old 10-19-2018, 02:59 PM   #7
Lovemyredline
Lovemyredline is on a distinguished road
2004 VUE 3.5L
2001 SC1
I was always told the engine will fail if the belt breaks on interference engine, at least that is what the dealership told me to scare me to replace it. I have never felt comfortable doing this job myself. Coming up on about 80K since my last replacement and I have been thinking about how I can get it done for less.
Add to Lovemyredline's Reputation
Rate the quality of this post and help Lovemyredline reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lovemyredline is offline   Reply With Quote
Old 10-23-2018, 01:06 PM   #8
Vue6
Vue6's Avatar
2006 VUE Red Line
...IT'S HIT OR MISS WITH A TIMING BELT FAILURE, ALOT OF VARIABLES, ENGINE RPM AT THE TIME, SPEED, ETC. I WAS LUCKY MYSELF. IF YOU DO IT YOURSELF JUST FOLLOW THE DIRECTIONS IN THE AISEN KIT , IT'S REALLY NOT THAT BAD, JUST TAKE YOUR TIME, DC
Timing marks off now. Timing belt change. Difficilus Vue General 4 12-06-2015 11:46 PM
Changing Timing Belt on a Saturn Vue 2002 AWD and without the timing belt tool kit Joelsaturnvue Vue Tech 16 03-13-2013 01:02 PM
Instalation instructions for Timing Belt from Gates timing belt kit. clean93 L-Series Tech 8 01-12-2012 07:15 PM
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 04:55 PM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 09:23 AM
