Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Green Line
Old 07-24-2021, 12:07 PM   #1
tony_gl
tony_gl is on a distinguished road
2009 VUE Green Line
Default Door lock/unlock actuators losing power
2009 Vue Hybrid, has been with me for a couple of years now.
A couple weeks ago it has started to loose power on door lock/unlock actuators, not that they don't work at all, it feels more more like if voltaje were dropping each time system is used, first time it gives you full cycle, second time it barely reached unlock position, thirds time you can see how the lock post try to move, but don't do anything.
No other electrical issues that I'm aware of...
Any thoughts greatly appreciated.
Thanks!!!
tony_gl is offline   Reply With Quote
Old 07-24-2021, 01:25 PM   #2
Default Re: Door lock/unlock actuators losing power
Wiring connections; loose, corrosion on male/female terminals, chafing of one or more wires shorting to ground, fuse connection corrosion, corroded/loose ground(s).
Old 07-26-2021, 02:40 PM   #3
tony_gl
2009 VUE Green Line
Any diagrams laying around to follow, anyone!?
Understanding how the system works might help me a lot in pinpointing the possible malfunction...
Thanks!!
Old 07-26-2021, 04:43 PM   #4
Other than members posting wiring diagrams or pdfs (if any have them), searching online may provide free diagrams. The alternatives are subscribing to Alldata.diy or Mitchell for online service manuals
Old 07-27-2021, 09:46 PM   #5
bern
2006 ION-2 Sedan
This is the symptoms of failing door latches replace the failing latches. Sometimes several or all fail about the same time.
2004 Ion 2 Door lock actuators djsted Ion General 1 06-10-2014 12:43 PM
Power door locks faint click but no lock/unlock 800xl S-Series Tech 0 03-19-2013 06:25 PM
1997 SC2 power door lock actuators ExHempKnight S-Series Tech 7 01-14-2009 08:06 PM
Power door locks lock, but won't unlock itsnotme1988 S-Series Tech 7 05-12-2008 10:01 PM
L power door lock actuators Iceman L-Series Tech 3 08-04-2001 11:32 PM
