Old 05-03-2000, 08:05 AM   #1
abkaiser
abkaiser will become famous soon enough
Default shifting in opposite direction okay?
If I'm going in reverse, about 5 MPH, is it okay to shift to forward, gradually give the car some clutch, and give clutch and gas to stop the car, and start moving it forward? Or is that bad for the transmission/clutch? I do it sometimes because it's quicker and more convienient and smoother than using the brake.
Again, this is manual trans.
Thanks,
Andy
Add to abkaiser's Reputation
Rate the quality of this post and help abkaiser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
abkaiser is offline
Old 05-03-2000, 09:40 AM   #2
Jeff
Guest
Posts: n/a
Default
Definately stop the car before putting it into first and proceeding. You won't kill it if you don't, but your clutch will wear out faster. Spend a few seconds today, save some miles tomorrow. My '92 SC's got 90,000 miles on the original clutch, and I always stop before going forward.
Add to Jeff's Reputation
Rate the quality of this post and help Jeff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-03-2000, 10:05 AM   #3
Walburger_97SC2M
Walburger_97SC2M is on a distinguished road
Default
Not to be an antagonist but....
I've got 110k miles on an original clutch for my 97SC2. I always use the clutch to push the car around (Rev -> 1st, hill hold, etc.) Not to mention the car is driven like a race car (Nascar style downshifts at lights, etc - Who needs brakes?).
The clutch has held up fine, and is just starting to not have that "factory fresh" feel. I'll prolly replace it at the end of the summer when it hit's 130k (now that I've got an engine support - Thanks Sattech.)
It's my impression that the Saturn transaxles are pretty bulletproof.
Just my $0.02.
- w
Add to Walburger_97SC2M's Reputation
Rate the quality of this post and help Walburger_97SC2M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Walburger_97SC2M is offline
Old 05-03-2000, 10:46 PM   #4
Jon94SoLo2
Guest
Posts: n/a
Default
I agree with Walburger that the clutch is prety durable, but why put more wear on it than necessary? The clutch isn't designed to stop the car, it's designed to make it go. Use brakes for stopping and clutch for going. You're not really saving much time anyway.
Jon
By the way, I too drive prety agressively and have 117,000 miles on my original clutch. Had it inspected by the dealer and was told it needed no servicing and felt fine. I agree, but was just checking.
Add to Jon94SoLo2's Reputation
Rate the quality of this post and help Jon94SoLo2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-05-2000, 09:15 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
use the brakes!! that's what the brakes are for. doing that will burn out much sooner. brake pads/shoes cost $50-100 per set and you can replace them in 15-30 minutes in the back yard with a jack and jack stands. a clutch is $250-300 and takes a few hours to replace. the stock clutch on my 92 sc lasted 103,000 miles before the tips on the fingers on the pressure plate snapped from too many 4000 rpm launchs at the drag strip. the friction material was still good though but i use the brakes to stop in reverse before taking off in first. i don't hold the car on hills with the clutch either.
eRic 02sc2 is offline
A Little Direction- BigJonCA S-Series Tech 8 11-28-2009 08:22 AM
rebuilding the engine, and I need direction ASE_Tek0312 S-Series Mods 6 03-15-2008 06:59 PM
Please someone point me in the right direction!! Red Sc2 S-Series General 0 07-25-2007 02:26 AM
Boeing is going in opposite direction than Saturn cdavidhess General Saturn Discussion 28 07-14-2007 07:45 PM
Need direction! cbea1124 L-Series Tech 0 12-28-2006 03:28 PM
